Only th edrivers door unlocks?
kerrys914
Member - Posts: 9
Posted: October 03, 2004 at 5:33 PM / IP Logged
I just installed an alarm/remote start to my 2002 Liberty. Only th edrivers door will unlock with the remote.
Is there anyway to unlock all doors with the same button? The OEM remote needs two presses to unlock the doors. The alarm I installed does nothing with two presses.
Cheers
Kerry
Audi 2002
TooDark
Copper - Posts: 163
Posted: October 03, 2004 at 6:07 PM / IP Logged
you are going to have to find the wire for the rest of the doors and power those wires with the unlock/lock from the alarm/RS
Moderator - Posts: 12,488
Posted: October 03, 2004 at 9:10 PM / IP Logged
What did you use for the resistance of the unlock wire ? This is what I have: Lock is negative trigger thru a 1.4K ohm resistor and unlock is negative trigger thru a 426 ohm resistor. MUST use relays.
Tuesday, December 23, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
