Can someone help me with this?
spittin2rock
Member - Posts: 22
Posted: October 06, 2004 at 1:20 AM / IP Logged
I'm using this diagram and trying to do this here's this link... https://www.the12volt.com/relays/page5.asp#drto
I just need a little bit of help.  The Radio's accessory wire corresponds with what wire on my stereo Would that be my power wire (red) on my stereo.  If not exactly which wire.  Where it has "fused 12v+"  Do I wire it to a fuse or do I use it as a power wire like using my constant power wire (yellow).  If you could explain that to me I would greatly appreciate it.
dxav
Silver - Posts: 314
Posted: October 06, 2004 at 8:04 AM / IP Logged
Fused 12V+ Simple means the power wire being connected to the PLUS side of your battery needs to have a series fuse inline close to the battery. Find the current rating of your system, and find the closest HIGHER value, then wire the fuse in series. You will need a fuse holder.
           Wire            Wire
[Battery] ------- [Fuse] --------- [Relay Pin (from the diagram]
DXAV
Wednesday, March 18, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
