Subsonic Filter?
thapimpfromchi
Silver - Posts: 616
Posted: October 06, 2004 at 3:12 PM / IP Logged
Hey guys, i'm just lookin at the spec sheet on my sub, to make a box, and it says to use a subsonic filter for the box I was looking at. What is a subsonic filter, and why would I use it with a ported box?
1990 Honda Civic HB:
Clarion DXZ545MP H.U.
2- 6.5" Power Acoustik interiors
Diamond Audio 600.1 amp
Diamond Audio 15" M6MKII
Pyramid PB881X 4 CH. Amp
thapimpfromchi
Silver - Posts: 616
Posted: October 06, 2004 at 3:20 PM / IP Logged
this is wierd. the 15" sub (the one i have) has a lower xmax than the 12 and the 10 inch versions. the 10 inch version has the highest actually. 18.3mm for the 10" sub, only 16mm for the 15" is that wierd to anyone besides me?
pimpincavy
Silver - Posts: 880
Posted: October 06, 2004 at 3:27 PM / IP Logged
A subsonic filter is used to filter out certin notes. Usually its used to block any Hz levels under 20. The human ear cannot hear anything under 20Hz, yet some songs have notes below that. The subsonic filter removes these notes so the amp and subs do not need top work at making notes we cannot hear. Quite a few amps have these, im not sure if you can get one to add on to a amp or not. Im also not sure why they would recommed this when dealing with a box. Maybe someone else can shed some light on that matter.
DYohn
Moderator - Posts: 10,741
Posted: October 06, 2004 at 3:43 PM / IP Logged
For ported enclosures, best power handling performance and maximum speaker protection is obtained by using a sub-sonic (basically a high-pass filter) just below the port tuning frequency.  For sealed enclosures, a subsonic is used simply to keep very low frequencies from eating up amplifier power since the woofer cone remains dampened.  They are also called rumble filters.  If your amp or crossover or line driver does not have one built in, there are a few stand-alone filters available (Harrison Labs makes a nice one.)
thapimpfromchi
Silver - Posts: 616
Posted: October 06, 2004 at 4:04 PM / IP Logged
i have a knob for sub bass.. is that the same thing?
DYohn
Posted: October 06, 2004 at 4:14 PM / IP Logged
Probably not, but what's the amp?
jeffchilcott
Platinum - Posts: 2,483
Posted: October 06, 2004 at 4:16 PM / IP Logged
no.    the knob is a gain control...you should have a crossover on your amp settings....As far as the excursion goes.   alot of sub makers are like this.   hell my eclipse's are light that, I have seen most audiobahn subs are like that as well...
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
thapimpfromchi
Silver - Posts: 616
Posted: October 06, 2004 at 6:48 PM / IP Logged
no, not the gain control. its got a sub bass knob too. its a Diamond Audio D3 600.1 I would take a picture for u but i cant find my digital camera at the moment.
furflier
Copper - Posts: 236
Posted: October 06, 2004 at 7:01 PM / IP Logged
The bass knob will boost your bass @ a certain freq. at around 45hz.
DYohn
Posted: October 06, 2004 at 7:02 PM / IP Logged
No, that control is a bass boost with frequency control.  It's explained in your owner's manual.  The amp does not include a subsonic filter.
Wednesday, September 17, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
