2004 Nissan Frontier VSS
jonbth
Member - Posts: 42
Posted: October 08, 2004 at 1:25 PM / IP Logged
I have a Blaupunkt Seattle reciever with automatic sound. I need to tap into the VSS wire for it to work. Does anyone know what color wire it is and where to tap into it?
mo12v
Posted: October 08, 2004 at 5:26 PM / IP Logged
VSS Wire: LOCATION 4- 2ND ROW FROM TOP OF ECM 4TH POSITION TO RIGHT OF BOLT IN ECM
VSS Wire Color: GREEN/ BLACK
VSS Pulse: 2000
VSS Tach Wire: LOCATION 16- 2 PIN CONNECTOR AT DISTRIBUTOR
Tach Signal Wire Color: BLACK/ RED
Brake Switch Positive: RED / YELLOW
Brake Switch Negative: RED / GREEN
MO
