Ignition Cable and Hyundai Santa Fe
DaRacerz
Member - Posts: 13
Posted: October 10, 2004 at 12:30 PM / IP Logged
Hello,
Have an issue. 04 Hyundai 2.7 L Santa Fe. Here's the deal. DEI claims 2 ignitions. Pink as Primary, Blue as secondary. When I check with voltmeter, heres what I get
On acc, blue and pink get no voltage
on run/on, blue and pink get 12v
on start, blue gets 12v, pink drops to about 1V
So what does this mean??? Should I still connect the Pink as primary ignition as it says? Hopefully i'll get no problems...
DaRacerz
Member - Posts: 13
Posted: October 10, 2004 at 12:36 PM / IP Logged
btw, i forgot to mentin this is for a clifford rs3.5
Teken
Gold - Posts: 1,492
Posted: October 11, 2004 at 2:53 AM / IP Logged
Blue is the primary, Pink is the secondary Ignition. Second ignition will test one of two ways. It will test with the key switch in run position only, or will test just like main ignition.
Like main ignition, it will never show power in the accessory position. If the second ignition shows power only in the run position then the accessory output of a remote start device may be used to power the wire.
Accessory is green. This wire will test with the key switch in the accessory and run position, but never in the start position.
Regards
EVIL Teken . . .
DaRacerz
Member - Posts: 13
Posted: October 11, 2004 at 7:28 PM / IP Logged
ok kewl, was woundering why i was geting the result i did. works great. thx.
Friday, May 3, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
