need help installing a head unit
a6audi
Member - Posts: 9
Posted: October 10, 2004 at 11:14 PM / IP Logged
need help installing a head unit in my 98 audi a6 quattro with the bose system, when i connect the wiring harness the unit turns on but i only hear sound from wat appears to be a tweeter, the wiring harness cables are : two cables for each speaker and ground, power, etc, etc. but on a second piece of harness it has another ground and a positive for a speaker there are four of those, in other words three speaker cables for each speaker, the told me i ould have to bypass the internal amp or something like that, or can some one tell me wat to do... HELP PLEASE!!!
<---audi a6 quattro
Drey
Member - Posts: 35
Posted: October 11, 2004 at 12:06 AM / IP Logged
i'm not too familier with that particular bose system... but, i know a lot of bose systems use 1ohm drivers meaning you'd have to replace the speakers with your headunit.  to bypass the amp you can run new speaker wire to your speakers or find your amp and locate the output and bypass the amp.
a6audi
Member - Posts: 9
Posted: October 11, 2004 at 12:09 AM / IP Logged
when i find the amp how do i bypass it ?
<---audi a6 quattro
jeffchilcott
Platinum - Posts: 2,483
Posted: October 11, 2004 at 7:29 PM / IP Logged
you will have to run wires from the speaker out's on your radio to the amp outputs for each speaker or just run wires to each speaker from the radio. but if your speakers are 1 ohm then you wont be able to power them with the head unit.   you will cook it
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
a6audi
Member - Posts: 9
Posted: October 12, 2004 at 5:07 PM / IP Logged
many people have told me that i need a interface, is it true or how could i do it?
<---audi a6 quattro
a6audi
Member - Posts: 9
Posted: October 12, 2004 at 5:08 PM / IP Logged
how do i know if its a 1 ohm speaker
<---audi a6 quattro
clank
Member - Posts: 35
Posted: October 14, 2004 at 7:18 PM / IP Logged
use a multi meter to measure resistance.  You can use a premium sound integration piece also if you do not want to replace all the speakers and run new wires
Saturday, December 27, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
