Remote Start - install troubleshooting
apicton
Posted: October 11, 2004 at 10:14 AM / IP Logged
I just purchased and am installing a Nitro 2 way remote starter/alarm/entry kit in a 2004 Kia Sedona minivan. I don't have the whole thing done yet, but I'm trying to test the starting.
The doorlocks aren't hooked up yet, but the alarm works when the car is bumped.
When I use the remote to start the vehicle, it turns over, but doesn't fire. With the key, it starts right away.
I haven't yet hooked up the doorlock wires, the signal lights, or the A/C wire. Would any of these cause it not to start for any reason?
I haven't been able to find a manual or a wiring diagram for a 2004 Kia, but I WAS confident I tapped into the correct wires until it didn't fire...
I'd appreciate any advice. thanks.
Andy
mo12v
Posted: October 11, 2004 at 10:21 AM / IP Logged
How is the RS set-up?  Current Sense, Tach, Spark Plug, etc.??
Wouldn't U think it would be best to Install completly first?
This is what I have:
Constant 12 voltsREDIGNITION SWITCH HARNESS
Ignition 12 voltsWHITEIGNITION SWITCH HARNESS
StarterBLACK / YELLOWIGNITION SWITCH HARNESS
Dome LightWHITE/ RED (-)TOP OF FUSE BOX
Trunk Pin SwitchGREEN/ BLACK (-)INSTRUMENT CLUSTER, IN LEFT PLUG
Parking LampRED / BLACK (+)DRIVER KICK PANEL, REAR HARNESS
Power LockWHITE/ BLACKIN PLUG TO THE LEFT
Power UnlockRED / GREENSTEEERING COLUMN
Negative Pulse Door Lock
Accessories
Window UpD\ RED P\RED / YEL D\ RED / BLU P\ RED / WHT
Window DownF/ GREEN F/GRN/YEL R/ BLU/WHT R/ GRN/WHT
Ign Key Warn
Trunk Release
OEM HornYELLOW/WHITE (-)BASE OF STEERING COLUMN
HeadlightsRED / BLACKBOTTOM OF STEERING COLUMN
OEM Alarm Arm
OEM Alarm Disarm
Remote Start
Tach SignalYELLOW/REDINSTRUMENT CLUSTER, IN LEFT PLUG
Ignition #2
Ignition #3
AccessoryGREENIGNITION SWITCH HARNESS
Neutral Safety
Brake LightWHITE (+)AT SWITCH ABOVE BRAKE PEDAL
Reverse Light
Rear Window Defrost
MO
apicton
Posted: October 11, 2004 at 11:19 AM / IP Logged
Hi there, thanks for the info.
This is my first attempt to install a multi-functional system (I did a single remote start a couple years ago, but there was a lot less to it...) and I wanted to test my progress before deciding if I should turn it over to a professional.
Maybe it's normal for it not to start until I have the other components installed, I was just trying to get some idea if I had done something wrong before I went any further. I'll finish up and test it again.
thanks again for the wire chart.
Andy
saleen49
Copper - Posts: 99
Posted: October 11, 2004 at 12:50 PM / IP Logged
 does your car have a pats type of anti-theft (chip in the key)? I am guilty of testing an unfinished system also and if the remote start part is incomplete or incorrect it won't start but this is a great way to learn trouble shooting i wouldn't give up but thats just me,
Monday, February 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
