power wire
jessexpress
Member - Posts: 6
Posted: September 30, 2002 at 4:58 PM / IP Logged
Hey guys I have a 94 Ford Escort and I was wondering if anyone has worked on one of these or anything similar.  I'm just wondering where the most convenient place to run the power wire would be.  Does anyone know where there is a hole in the firewall in this car?
Jesse
djfearny2
Silver - Posts: 810
Posted: September 30, 2002 at 7:33 PM / IP Logged
to run a power wire depending on gauge if it is 8 or ten than you can usually find a rubber cover that you can slip it through drivers side that will run right through firewall. it not too hard if you running an amp you best bet is to run rca cables on opposite side of battery so if you bat is on drivers side than run rca on passanger side make sure you dont run power and and rca on the same side most of the time you'll get engine noize
Jon
Installer/Help Technician
---coral springs florida---
DeathsJester12V
Silver - Posts: 352
Posted: October 01, 2002 at 6:19 PM / IP Logged
all else fails...double check and drill a hole
Đễẳ†ђş 12\/ Ĵęśŧē®™
Monday, May 4, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
