04 toyota sienna schematics
desh187
Copper - Posts: 310
Posted: October 12, 2004 at 11:35 PM / IP Logged
Need wiring info for 04 toyota sienna .Need to install alarm auto start.
Thanks.
draasch
Gold - Posts: 2,172
Posted: October 13, 2004 at 7:29 AM / IP Logged
Make:   Toyota
Model: Sienna
Year:    2004
Alarm
Constant 12 volts WHITE/ RED 14 GAGE IGNITION SWITCH HARNESS
Ignition 12 volts BLACK 14 GAGE IGNITION SWITCH HARNESS
Starter BLACK / YELLOW 14 GAGE IGNITION SWITCH HARNESS
Dome Light RED / WHITE (-) 14 PIN CONN LOWER LEFT OF FUSE BOX
Trunk Pin Switch RED / WHITE (-) SAME CIRCUIT AS DOME LIGHT
Parking Lamp GREEN/ BLACK (-) AT HEADLIGHT SWITCH
Power Lock L GREEN DRIVERS KICK WHT 18 PIN CONN #201
Power Unlock BLUE DRIVERS KICK WHT 18 PIN CONN
#201 See Negative Pulse Door Lock Diagram
Accessories
Window Up D\ GREEN P\ BLK/WHT D\ PINK P\ RED / BLK AT MAIN #211
Window Down F/ RED F/ RED / BLU R/ BLU/RED R/ BLACK SWITCH
Ign Key Warn BLUE/BLACK (-) IGNITION SWITCH HARNESS
Trunk Release YELLOW/RED (-) AT OVER HEAD CONSOLE *
OEM Horn GREEN/ BLACK (-) AT STEERING COLUMN
Headlights RED / GREEN (-) STEERING COLUMN HARNESS
OEM Alarm Arm L GREEN DRIVERS KICK WHT 18 PIN CONN
OEM Alarm Disarm BLUE DRIVERS KICK WHT 18 PIN CONN
Oem Hood Trigger: RED / WHITE (-) IN BLACK Conn. Top Left of Fuse Box. * Relay And 2500 Mfu Polarized Capactor Needed To Expand Pulse. * Open Slider-YELLOW /GREEN, Passenger Side-VIOLET, @ Roof Console Switch
Remote Start
Tach Signal BLACK/ ORANGE BEHIND GLOVE BOX TOP CONN OF PCM.
Ignition #2 BLACK / YELLOW 18 GAGE IGNITION SWITCH HARNESS #239
Ignition #3
Accessory PINK IGNITION SWITCH HARNESS
Neutral Safety NON GROUNDING TYPE
Brake Light GREEN / WHITE (+) AT FUSE BOX WHT CONN ABOVE RELAYS
Reverse Light RED / BLACK (+) IN HARNESS AT LIGHT
Rear Window Defrost YELLOW /GREEN (-) TOP RIGHT OF FUSEBOX RELAY
#239 See Immobilizer Bypass Diagram (DB-PKT NOT Compatible)
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Friday, April 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
