2000-01Pontiac Grand Prix Wire Diagram
newinstaller
Copper - Posts: 160
Posted: October 13, 2004 at 7:31 PM / IP Logged
Hi,
I am looking for a wire diagram for a 2000-01Pontiac Grand Prix
I am installing a Compustar 2WFMAS Alarm/Starter
Anyone got any DEI Diagrams?
snguyen
Silver - Posts: 281
Posted: October 13, 2004 at 7:39 PM / IP Logged
Pontiac
Grand Prix
1997-2002
Remote Starter Wiring Colors and Notes
Function
Vehicle Color
Location
Start:
YELLOW
IGNITION SWITCH HARNESS *
Ignition #1:
PINK
Ignition #2:
WHITE
IGNITION SWITCH HARNESS (ECM)
Ignition #3:
N/A
Accessory:
ORANGE
IGNITION SWITCH HARNESS (HEAT/AC)
Brake Light:
WHITE (+)
AT SWITCH ABOVE BRAKE PEDAL
Tach Signal:
WHITE
AT POWERTRAIN CONTROL MODULE
Parking Lights:
BROWN (+)
AT HEADLIGHT SWITCH
Headlights:
YELLOW (+)
AT HEADLIGHT SWITCH
OEM Alarm Disarm:
ORANGE / BLACK (-)
# PIN CONNECTOR IN DR. KICK PANEL
OEM Alarm Arm:
N/A
SEE NOTES BELOW **
Diesel Glow Plug:
Clutch Bypass Wire:
Notes:
* 1999+ Vehicles Are Equipped With GM's PassKey III Anti-Theft System, See Installation Note #144 - Bypassing Transponder Theft Systems. To program additional keys for GM PASSK-KEY III please See Note #147.
Pontiac
Grand Prix
1997-2002
Alarm and Keyless Entry Wiring Colors and Notes
Function
Vehicle Color
Location
Constant +12 Volts:
RED & RED
Starter Kill:
YELLOW
Ignition +12 Volts:
PINK
Dome Lights/Superv:
TAN (DR) & D BLUE
(ALL OTHER DOORS) (-) AT BCM ***
OEM Horn:
BLACK (-)
STEERING COLUMN HARNESS
Power Lock:
L BLUE
# PIN CONNECTOR IN DRIVER KICK
Power Unlock:
WHITE
PANEL OR AT BODY CONTROL MODULE ****
Trunk Release:
BLACK/ WHITE (+)
AT TRUNK RELEASE SWITCH
Alarm Input Wire:
TAN (DR) & D BLUE
Notes:
*** TAN (-) Wire Covers Driver Door Only, DK. BLUE (-) Covers All Other Doors. Diode Isolation Needed, Cathode (Band) Side Of Diode Faces OEM Wires. **** See Note #201- Negative Pulse Door Lock Diagram.
newinstaller
Copper - Posts: 160
Posted: October 13, 2004 at 7:43 PM / IP Logged
thanks again for your help
