97 buick Century Alarm wiring info
betomtz
Posted: October 14, 2004 at 3:52 PM / IP Logged
HELP
Do any body have the alarm wiring (Security information).
I have looked in the main database, strange, but the 97 model is the onlyone missing.
Thanks in advance
Luis
LMartinez
Teken
Gold - Posts: 1,492
Posted: October 14, 2004 at 3:59 PM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - BUICK / CENTURY / 1997 / Remote Start
12volts red    +   ignition harness
Starter yellow    +   ignition harness
Second Starter
Ignition pink    +   ignition harness
Second Ignition white or green    +   ignition harness
Third Ignition
Accessory orange    +   ignition harness
Second Accessory
Keysense
Power Lock RED / black    -   drivers kick or BCM
Notes: BCM is to the left of the steering column
Power Unlock ORANGE / black    -   drivers kick or BCM
Lock Motor gray      drivers kick panel
Unlock Motor tan      drivers kick panel
Parking Lights+ lt. blue      at switch
Notes: Larger of the two at the light switch. Can also find BROWN / white in the passenger kick panel in the harness to the rear.
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger dark blue/white    -   drivers kick or BCM
Dome Supervision use door trigger
Trunk/Hatch Pin ORANGE / black    -   light in trunk or BCM
Hood Pin
Trunk/Hatch Release brown    -   relay behind glove box
Power Sliding Door
Factory Alarm Arm
Factory Alarm Disarm
Disarm No Unlock
Tachometer pur/wht or white    ac ignition control module
Wait to start
Brake Wire white    +   brake pedal switch
Parking Brake
Horn Trigger black    -   steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
Immobilizer Bypass Module: Required: Yes Type: VATS Part #: 652T resistor pack
Notes: See DirectFax document 1049 for interface information.
Teken
Gold - Posts: 1,492
Posted: October 14, 2004 at 4:01 PM / IP Logged
Buick
Century
1997-2000
Remote Starter Wiring Colors and Notes
Function
   Vehicle Color
Location
Start:
   YELLOW
IGNITION SWITCH HARNESS *
Ignition #1:
   PINK
Ignition #2:
   DARK GREEN
IGNTION SWITCH HARNESS
Ignition #3:
   N/A
Accessory:
   ORANGE
Brake Light:
   WHITE
AT SWITCH ABOVE BRAKE PEDAL
Tach Signal:
   WHITE
AT ICM TOP CENTER REAR OF ENGINE
Parking Lights:
   LIGHT BLUE
AT HEADLIGHT SWITCH
Headlights:
OEM Alarm Disarm:
   LT. GREEN
DRIVER'S KICK PANEL
OEM Alarm Arm:
   N/A
Diesel Glow Plug:
Clutch Bypass Wire:
Notes:
   * This Vehicle Is Equipped With GM's VATS Passive Security Theft System. See Note # 237 - Bypassing VATS Passive Theft Security System Diagram. Some vehicles may be equipped with a transponder - See Note#144
Buick
Century
1997-2000
Alarm and Keyless Entry Wiring Colors and Notes
Function
   Vehicle Color
Location
Constant +12 Volts:
   RED
Starter Kill:
   YELLOW
Ignition +12 Volts:
   PINK
Dome Lights/Superv:
   DK. BLUE/WHITE
AT BCM LEFT SIDE OF DASH I/P
OEM Horn:
   BLACK
IN STEERING COLUMN HARNESS
Power Lock:
   RED / BLACK (-)
DRIVER'S KICK OR BCM BEHIND THE DASH
Power Unlock:
   ORANGE / BLACK (-)
TO THE LEFT OF THE STEERING COLUMN*
Trunk Release:
   BLACK/ WHITE (+)
AT TRUNK RELEASE SWITCH
Alarm Input Wire:
   DK. BLUE/WHITE
Notes:
* See Note # 201 - Negative Pulse Door Lock Diagram
Teken
Gold - Posts: 1,492
Posted: October 14, 2004 at 4:02 PM / IP Logged
CENTURY   1997-2004
WIRE COLORS LOCATION
12 VOLTS CONSTANT RED (2) IGNITION SWITCH HARNESS
IGNITION 1 PINK (+) IGNITION SWITCH HARNESS
IGNITION 2 WHITE or GREEN (+) IGNITION SWITCH HARNESS
ACCESSORY /HEATER BLOWER ORANGE (+) IGNITION SWITCH HARNESS
STARTER YELLOW (+) IGNITION SWITCH HARNESS
PARKING LIGHTS (+) LT. BLUE at HEADLIGHT SWITCH, use the larger of the (2) LIGHT BLUE wires.
DOME LIGHT BLUE/WHITE (-) at BCM See NOTE**
POWER DOOR LOCK RED / BLACK in DRIVERS KICK PANEL or BCM (TYPE "B") See NOTE**
POWER DOOR UNLOCK ORANGE / BLACK in DRIVERS KICK PANEL or BCM (TYPE "B") See NOTE**
TRUNK RELEASE WHITE (-) at BCM ABOVE DRIVER'S KICK PANEL See NOTE**
TACH SENSOR VIOLET/WHITE or WHITE at IGNITION COIL Module
BRAKE WHITE (+) at BRAKE SWITCH
HORN BLACK (-) at STEERING COLUMN HARNESS
FACTORY ANTI-THEFT VATS (Pass Key I) Pill in Key Requires part #791 bypass module
NOTE**    The BCM (Body Control Module) is to the left of the steering column.
Teken
Gold - Posts: 1,492
Posted: October 14, 2004 at 4:05 PM / IP Logged
Make:   Buick
Model: Century
Year:    1997
This Database Was Last Updated On:    9/16/2004
Index #: 1659
Alarm
Constant 12 volts RED (2) IGNITION SWITCH HARNESS
Ignition 12 volts PINK IGNITION SWITCH HARNESS
Starter YELLOW IGNITION SWITCH HARNESS
Dome Light D BLUE/WHITE (-) AT BODY CONTROL MODULE *
Trunk Pin Switch ORANGE / BLACK (-) AT BODY CONTROL MODULE *
Parking Lamp L BLUE (+) AT HEADLIGHT SWITCH
Power Lock RED / BLACK AT BODY CONTROL #201
Power Unlock ORANGE / BLACK MODULE *
* Body Control Module Located Behind Driver Dash To The Left Of The Steering Column. #201- See Negative Pulse Door Lock Diagram.
View Diagrams
Accessories
Window Up D\ D BLUE P\ L BLUE D\ D GREEN P\ L GREEN @ MAIN #211
Window Down F/ BROWN F/ TAN R/ PURPLE R/ PURPLE SWITCH
Ign Key Warn L GREEN (-) IGNITION SWITCH HARNESS
Trunk Release BLACK/ WHITE (+) AT TRUNK RELEASE SWITCH #231
OEM Horn BLACK (-) STEERING COLUMN HARNESS
Headlights YELLOW (+) AT HEADLIGHT SWITCH
OEM Alarm Arm N/A NO OEM ALARM PRESENT
OEM Alarm Disarm N/A IN SCHEMATICS
#211- See Reversal Rest At Ground Power Window Circuit Diagram. #231- See Positive Pulse Trunk Release Diagram.
View Diagrams
Remote Start
Tach Signal WHITE AT POWERTRAIN CONTROL MODULE *
Ignition #2 ORANGE IGNITION SWITCH HARNESS (HEAT/AC)
Ignition #3 D GREEN IGNITION SWITCH HARNESS (BCM & PCM)
Accessory BROWN IGNITION SWITCH HARNESS
Neutral Safety YELLOW (-) AT SWITCH ON TRANSAXLE
Brake Light WHITE (+) AT SWITCH ABOVE BRAKE PEDAL
Reverse Light L GREEN (+) AT SWITCH ON TRANSAXLE
Rear Window Defrost N/A TIMER BUILT INTO SWITCH
* Powertrain Control Module Located On Front Of Engine In Air Cleaner Housing.
View Diagrams
betomtz
Posted: October 14, 2004 at 4:11 PM / IP Logged
THANKS A LOT
GOD BLESS YOU.
LUIS MARTINEZ
LMartinez
Teken
Gold - Posts: 1,492
Posted: October 14, 2004 at 5:03 PM / IP Logged
Please do take the time to plan, prep, and measure all contacts to verify their function(s) with your DMM.
Regards
EVIL Teken . . .
Sunday, February 15, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
