Isuzu Dash Light Issue
tampa77
Copper - Posts: 65
Posted: October 16, 2004 at 9:28 PM / IP Logged
Good Evening,
I installed a KE/RS in a 94 Isuzu Rodeo, all went well however three days larter the owner relized the dash lights do not work. I checked all fuses and all are ok. The bulbs are all fine too. The Parkers, headlights all work. When the key fob is used the lights flash and all features are fine. I know I saw the dash lights come on then off with the light flash while remote started when I finished the install, unsure why they will not work now and I have nothing left to check? The unit is a DEI Avital and I only hooked up a door actuator for door locks, lights and the remote start. Anyone have any Ideas or run into this issue? Any help GREATLY appreaciated, it is a friend, but I dislike having issues that I am unable to reslove.
     tampa77
mo12v
Posted: October 16, 2004 at 9:40 PM / IP Logged
Did U check Dash Dimmer switch
MO
Sunday, April 12, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
