1995 mercury couger wire diagram?
sahall32
Member - Posts: 11
Posted: October 17, 2004 at 7:49 PM / IP Logged
installing a alarm/rs in a 1995 mercury couger and need the wire diagram.
Steve
mo12v
Posted: October 17, 2004 at 8:27 PM / IP Logged
This is what I have:
Constant 12 voltsORANGE / BLACK (5 TOTAL)IGNITION SWITCH HARNESS
Ignition 12 voltsRED / LIGHT GREENIGNITION SWITCH HARNESS
StarterRED / LIGHT BLUEIGNITION SWITCH HARNESS
Dome LightBLACK/ LT BLUE OR GRAY(+) EITHER PIN SWITCH *
Trunk Pin SwitchLIGHT GREEN/ YELLOW (-)AT TRUNK LIGHT (METER FOR RIGHT ONE)
Parking LampBROWN (+)HEADLIGHT SWITCH OR DRIVER KICK PANEL
Power LockPINK / YELLOWPASSENGER KICK PANEL OR
Power UnlockPINK/LIGHT GREENBEHIND GLOVE BOX **
* With OEM Keyless Entry Dome Light Wire Is GRAY (+),Without BLACK/ L BLU (+). Negative Pulse Door Lock Diagram
** Without OEM Keyless Entry Reversal Rest At Ground Door Lock
,With OEM Keyless Entry . It Is Common For Lock & Unlock Wire Colors To Reverse.  (Must Test From Pass. Sw)
Accessories
Window UpD\ WHT/BLK P\ TAN/L BLU @ MAIN SWITCH
Window DownR/ YEL S/ WHT/YEL
Ign Key WarnBLACK/ PINK (-)STEERING COLUMN HARNESS OR CHIME MOD.
Trunk ReleasePURPLE / YELLOW (+)RELEASE SW. OR DRIVER KICK PANEL
OEM HornDARK BLUE (-)STEERING COLUMN HARNESS OR AT RELAY
HeadlightsRED / YELLOW (+)HEADLIGHT SWITCH OR BEAM SELECT SW.
OEM Alarm ArmN/A
OEM Alarm DisarmDARK GREEN/ PURPLE*(-) IN EITHER KICK PANEL
Reversal Rest At Ground Power Window Circuit
Positive Pulse Trunk Release Diagram. * Has Also Been Found As L GREEN/ ORANGE In Either Kick Panel
Remote Start
Tach SignalORANGE / WHITEAT IGNITION CONTROL MODULE *
Ignition #2GRAY / YELLOW (2)IGNITION SWITCH HARNESS **
Ignition #3GRAY / YELLOWIGNITION SWITCH HARNESS **
AccessoryBLACK/ LIGHT GREENIGNITION SWITCH HARNESS **
Neutral SafetyNOT GROUNDING TYPE -OEM SWITCH OPENS STARTER CIRCUIT
Brake LightLIGHT GREEN (+)SWITCH ON TOP OF BRAKE PEDAL SUPPORT
Reverse LightBLACK/ PINK (+)SWITCH ON DRIVER REAR OF TRANSMISSION
Rear Window Defrost
* Ignition Control Module Located On Passenger Wheelwell. ORANGE / WHITE Located At Pin #2. ** See Tech Notes For Ignition Switch Layout.
See Powering Extra Ignitions
** Ignition Switch Layout: Starter..................RED / L BLUE. Ignition #1..............RED / L GREEN (Primary Ignition). Ignition #2..............GRAY / YELLOW (2) (Blower Motor) * Ignition #3..............GRAY / YELLOW (Heat/Ac Controls). Accessory................BLACK/ L GREEN (Radio/Wipers). * 2 Of The 3 GRAY / YELLOW Wires Listed Are The Same Circuit.
MO
Monday, February 23, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
