2001 Dodge Stratus R/T alarm wiring
anth541
Posted: October 01, 2002 at 9:29 PM / IP Logged
I'm looking for the wiring diagram for a 2001 dodge stratus rt. im wiring an alarm
Platinum - Posts: 12,488
Posted: October 01, 2002 at 9:33 PM / IP Logged
|              12V|WHITE/ red           |+  |ignition harness            |
|          STARTER|BLACK/ red           |+  |ignition harness            |
|         IGNITION|dk. green           |+  |ignition harness            |
|        ACCESSORY|blue/red            |+  |ignition harness            |
| SECOND ACCESSORY|blue/black          |+  |ignition harness            |
|       POWER LOCK|lt. GREEN/ black *2  |-  |drivers kick panel *1       |
|     POWER UNLOCK|orange *2           |-  |drivers kick panel *1       |
|       LOCK MOTOR|lt. green           |   |drivers kick panel *1       |
|     UNLOCK MOTOR|dk. GREEN/ red       |   |drivers kick panel *1       |
|    DISARM DEFEAT|blue/black          |   |passenger kick panel or *9  |
| PARKING LIGHTS +|grn/wht or pnk/blk  |   |low in drivers kick         |
|       HEADLIGHTS|orange              |-  |headlight relay under hood  |
|     DOOR TRIGGER|GREEN/ YELLOW        |-  |fuse box *8                 |
| DOME SUPERVISION|GREEN/ orange        |-  |fuse box *3                 |
|  TRUNK/HATCH PIN|red                 |-  |drivers kick panel *7       |
|TRNK/HTCH RELEASE|GREEN / WHITE         |5wi|drivers kick panel *7       |
|  FCTRY ALARM ARM|arms with lock      |   |                            |
|FCTRY ALRM DISARM|disarms with unlock |   |                            |
| DISARM NO UNLOCK|*6                  |   |                            |
|       TACHOMETER|*4                  |   |*4                          |
|      SPEED SENSE|WHITE/ blue          |   |center console *5           |
|       BRAKE WIRE|GREEN/ orange        |+  |brake pedal switch          |
|     HORN TRIGGER|lt. GREEN/ black     |-  |steering column             |
|           WIPERS|blu/org & blu/yel   |+  |wiper motor                 |
|  LF WINDOW UP/DN|RED / blk - grn/blk   |A  |drivers window switch       |
|  RF WINDOW UP/DN|RED / wht - green     |A  |drivers kick panel *1       |
| SUN RF OPN/CLOSE|not recommended     |   |                            |
|        RADIO 12V|ORANGE / black        |+  |radio                       |
|     RADIO SWITCH|WHITE/ black         |+  |radio                       |
| RADIO ILLUMINATE|GREEN / WHITE         |+  |radio                       |
|       LF SPEAKER|wht/blu - blk/blu   |   |radio                       |
|       RF SPEAKER|wht/red - blk/red   |   |radio                       |
|       LR SPEAKER|yel/blu - gry/blu   |   |radio                       |
|       RR SPEAKER|yel/red - gry/red   |   |radio                       |
Notes:
NOTE:  This vehicle is equipped with an immobilizer.  .  *1 Located in a black 32 pin plug.  *2 These are the door key cylinder wires. Meter the wires while turning the key in the drivers door. Unlock requires a double pulse. On vehicles without the factory alarm use purple for lock and lt. GREEN/ red for unlock, these are the door lock switch wires.  *3 In the plug on the upper right side of the fuse box under the driver side dash.  *4 Go to the test connector inside the fusebox under the hood, it is a T shaped plug. Tach is the terminal on the top left of the T, the wire under the terminal is white or WHITE/ red.    *5 Located in a large white 38 pin plug behind the radio.  *6 To disarm without unlocking, use a single pulse on the unlock wire.  *7 Located in a white 43 pin plug.  *8 Located in a black 19 pin plug on the back of the fuse box under the driver side dash.  *9 Also found in a black 20 pin plug on the front of the fuse box under the driver side dash.
