Remote starter Install on 95 ford winstar
n2o_2k
Member - Posts: 7
Posted: October 18, 2004 at 8:25 PM / IP Logged
Hi, I'm planing on installing a remote starter (bulldog, not the greatest but that's he's choice)on my friend's car but i got a couple of question. I've installed alarm before, how much of problem am i looking at for the remote starter. I don't know if the car is equiped with anti-theft system, how can I check your this. If the car has it, do i need the bypass module. For you guys who installed remote starter do you go with the tach or tachless installation, what's the pros and cons.
Thanks for your help
Teken
Gold - Posts: 1,492
Posted: October 18, 2004 at 9:03 PM / IP Logged
The vehicle does not have a immobilizer. Tach is the only tried and true method for consistent RS in cold weather conditions.
Using tach voltage many variables can come into play. The age of the battery, alternator, whether you have your HVAC on, is the starter going, if the vehicle is out of tune, etc.
If you want to keep your friend, and your sanity, you will do a direct tach connection.
Regards
EVIL Teken . . .
n2o_2k
Member - Posts: 7
Posted: October 24, 2004 at 9:49 PM / IP Logged
I need some help about the keyless entry that i'm trying to hook up. Is the car door locks a type "c" or type "B". Is it negative trigger or positive trigger or reverse polarity trigger.
Need your help on this please.
mo12v
Posted: October 24, 2004 at 10:15 PM / IP Logged
Power LockPINK / YELLOWDRIVER KICK
Power UnlockPINK/LIGHT GREENPANEL ***
With OEM Keyless :   Negative Pulse Door Locks
Without OEM Keyless:  Reversal Rest At Ground Door Locks
If Manufactured After 10/11/94 Negative Pulse Door Locks
Meter locks to be sure
OR
( 1995 Ford Windstar Alarm Information )
MO
