Directwire for 2003 Yukon
naamanf
Member - Posts: 22
Posted: October 19, 2004 at 8:58 PM / IP Logged
Could I please get the Directwire for a 2003 Yukon.  Thank you in advance.
Teken
Gold - Posts: 1,492
Posted: October 19, 2004 at 9:09 PM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - GMC / YUKON / 2003 / Remote Start
12volts red & RED / white   +   ignition harness
Starter yellow   +   ignition harness
Second Starter N/A
Ignition pink   +   ignition harness
Second Ignition white   +   ignition harness
Notes: To avoid the check engine light from coming on and possible damage to the automatic transmission, the second ignition in this vehicle MUST be powered when adding a remote start system.
Third Ignition N/A
Accessory orange   +   ignition harness
Second Accessory brown   +   ignition harness
Keysense lt. green   -   ignition harness
Power Lock use Directed module 456G
Notes: If Directed module 456G is not available, refer to DirectFax document 1601. Upper trim level vehicles may have a door lock switch on the right rear panel. If present use white (-) for lock and lt. blue (-) for unlock.
Power Unlock see power lock
Lock Motor gray      driver door module in door
Unlock Motor tan      driver door module in door
Parking Lights+ brown   +   driver kick panel
Parking Lights- gray/black   -   switch or BCM, brown plug, pin B2
Notes: The BCM (Body Control Module) is under the driver side dash. It has 6 plugs in it, the purple plug is on the back.
Hazards white   -   steering column
Turn Signal(L) green   +   steering column
Turn Signal(R) lt. green   +   steering column
Reverse Light lt. green   +   BCM, black plug, pin F
Door Trigger see notes   -   see notes
Notes: The driver door trigger is gray/black at the driver door module in the door. The RF door trigger is BLACK/ white at the passenger door module in the door. The LR door trigger is lt. blue/black, pin A3, and the RR is lt. GREEN/ black, pin A2, they are in the purple plug at the BCM. Use all four wires and diode isolate each.
Dome Supervision gray/black   +   BCM, black plug, pin E
Trunk/Hatch Pin pink/black   -   BCM, purple plug, pin A1
Hood Pin N/A
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm arms with lock
Factory Alarm Disarm lt. green   -   driver door module in door
Disarm No Unlock see factory alarm disarm
Tachometer white   ac   instrument cluster, pin A5 or PCM
Notes: The PCM (Powertrain Control Module) is in the left front of the engine compartment to the left of the fan shroud. The tach wire is in the green plug, pin 10.
For tach can also go to any of the ignition coils or injectors and use the wire that is NOT pink, black, or brown.
Wait to start N/A
Brake Wire white   +   brake pedal switch
Parking Brake lt. blue   -   switch or BCM, lt. blu plug, pin A7
Horn Trigger BLACK / YELLOW to black   -   column or BCM, gray plug, pin B9
Memory Seat 1 red   +   driver door module in door
Memory Seat 2 pink   +   driver door module in door
Memory Seat 3 N/A   +
Immobilizer Bypass Module: Required: Yes Type: Passlock 2 Part #: 555L or 555T
Notes: The Passlock 2 wire colors are yellow, black (org/blk), and RED / white (not used).
Teken
Gold - Posts: 1,492
Posted: October 19, 2004 at 9:12 PM / IP Logged
GMC
Yukon
2003-2004
Remote Starter Wiring Colors and Notes
Function
   Vehicle Color
Location
Start:
   Yello
Ignition Switch Harness*
Ignition #1:
   Pink
Ignition #2:
   White
Ignition #3:
   N/A
Accessory:
   Orange
Brake Light:
   Blue or White
At Brake Switch
Tach Signal:
   White or PURPLE / White
At PCM or Instrument Cluster*****
Parking Lights:
   Brown
In Kick Panel
Headlights:
   Not Recommended
OEM Alarm Disarm:
   Green
Inside of Drivers Door
OEM Alarm Arm:
   N/A
Diesel Glow Plug:
   N/A
Clutch Bypass Wire:
   N/A
Notes:
   * This vehicle is equippes with PASSLOCK II. Use Universal Alarm Bypass Module, Vehicle Specifi Bypass, or See Note #113. ****All DesignTech remote starters except the 2xx22 have an ignition 3 output - it is the WHITE/ black in the 'control harness.' This wire will be used to control the bypass module, if needed. ***** The tach wire at the instrument cluster is labeled as databus in the vehicle schematics, but it will supply a valid tach signal.
GMC
Yukon
2003-2004
Alarm and Keyless Entry Wiring Colors and Notes
Function
   Vehicle Color
Location
Constant +12 Volts:
   Red and RED / White
Starter Kill:
   Yello
Ignition +12 Volts:
   Pink
Dome Lights/Superv:
   White
At Light Under Dash
OEM Horn:
   Black (-)
At Steering Column Harness
Power Lock:
   See Note Below
Power Unlock:
   See Note Below
Trunk Release:
   N/A
Alarm Input Wire:
   White
At Light Under Dash
Notes:
** Base models may have negative triggered door locks at the BCM vehind the headlight switch.
Teken
Gold - Posts: 1,492
Posted: October 19, 2004 at 9:14 PM / IP Logged
Make:   GMC
Model: Yukon
Year:    2004
Alarm
Constant 12 volts RED (2) IGNITION SWITCH HARNESS
Ignition 12 volts PINK IGNITION SWITCH HARNESS
Starter YELLOW IGNITION SWITCH HARNESS
Dome Light GRAY/BLACK (+) AT UNDERDASH LIGHT
Trunk Pin Switch
Parking Lamp BROWN (+) DRIVERS KICK PANEL **
Power Lock GRAY SEE TECH NOTES
Power Unlock TAN FOR DOOR LOCK INFO
** Parking Light Wire Has Also Been Found As A BROWN / WHITE (+) High In Kick Or VIOLET (-) At Headlight Switch. Information Courtesy Of Installer!! Any Additional Information Appreciated!!
View Diagrams
Accessories
Window Up D\ BLUE P\ LT BLUE D\ BLUE P\BLUE @ Each Switch Due
Window Down F/ BROWN F/ TAN R/ BROWN R/BROWN To Data Link #211
Ign Key Warn LIGHT GREEN (-) IGNITION SWITCH HARNESS
Trunk Release
OEM Horn BLACK (-) STEERING COLUMN HARNESS
Headlights WHITE (-) AT HEAD LIGHT SWITCH
OEM Alarm Arm
OEM Alarm Disarm LT GREEN (-) AT DOOR MODULE INSIDE DRIVERS DOOR
#211 See Reversal Rest At Ground Type Window Circuit Wiring Diagram OEM Hood Pin Wire Is PINK/BLACK @ Switch On Top Of Radiator Support Information Courtesy Of Installer!! Any Additional Information Appreciated!!
View Diagrams
Remote Start
Tach Signal WHITE AT PCM * #238
Ignition #2 WHITE IGNITION SWITCH HARNESS
Ignition #3 ORANGE IGNITION SWITCH HARNESS
Accessory BROWN IGNITION SWITCH HARNESS
Neutral Safety WHITE (-) PCM CONN C3 PIN #13 *
Brake Light WHITE (+) AT SWITCH ABOVE BRAKE PEDAL
Reverse Light LIGHT GREEN (+) EITHER TAIL LT ASSY OR TRAILER CONN
Rear Window Defrost
*PCM Located On The Drivers Side Of The Motor. Tach Wire Is In The BLUE Conn (C1) Closest To The Firewall,Pin #49. Also Found Back Of Cluster in 24 pin GREY Conn Pin # A12 #238- See G.M. Passlock II Bypass Diagram Information Courtesy Of Installer!! Any Additional Information Appreciated!!
Teken
Gold - Posts: 1,492
Posted: October 19, 2004 at 9:16 PM / IP Logged
YUKON 2004
WIRE COLORS LOCATION
12 VOLTS CONSTANT RED IGNITION SWITCH HARNESS
IGNITION 1 PINK (+) IGNITION SWITCH HARNESS
IGNITION 2 WHITE (+) IGNITION SWITCH HARNESS
ACCESSORY /HEATER BLOWER ORANGE (+) IGNITION SWITCH HARNESS
STARTER YELLOW (+) IGNITION SWITCH HARNESS
PARKING LIGHTS (+) BROWN (+) LT. BLUE PLUG @ BCM *1
DOME LIGHT TAN (-) *SEE NOTES BELOW *2
POWER DOOR LOCK LT. BLUE BROWN PLUG @ BCM *1   (TYPE "A")
POWER DOOR UNLOCK WHITE BROWN PLUG @ BCM *1   (TYPE "A")
TACH SENSOR WHITE (-) @ ECM *SEE NOTES BELOW* 3
BRAKE WHITE (+) SWITCH AT BRAKE PEDAL
HORN BLACK (-) BROWN PLUG @ BCM
FACTORY DISARM LT. GREEN ( - ) DRIVERS KICK PANEL *4
FACTORY ANTI-THEFT PASSLOCK 2 Requires part # 791 bypass
NOTES: This vehicle has the PASSLOCK II immobilizer system, when adding a remote starter, it must be installed with a Part 791 BYPASS. Call 1-800-659-0764 to order.
*1 - The BCM is located behind the drivers side of the dash. The plugs on the BCM face towards the rear of the vehicle. The parking lights are in pin A5 and the headlights are in pin A11.
*2 - Use tan for the drivers door located in pin B4 of the purple plug, the passenger doors are a blue/white in the lt. blue plug, and the rear hatch pin is a pink/black in the lt. blue plug. You must diode isolate these wires.
*3 - Diesel wait to start wire is dk. blue (-) located at the instrument cluster. ECM is located near the battery, down low, between the fender and the fan under the black plastic cover. On the 4.3L, the tach wire is at pin 20 in the connector labeled *red*, and VSS wire is at pin 3 in the connector labeled *black*. On the 4.8L, 5.3L, and 6.0L, the tach wire is located at pin 10 in the *red* connector, and VSS wire is located in pin 50 of the *red*
*4 - Also found in the purple plug of the BCM.
naamanf
Member - Posts: 22
Posted: October 19, 2004 at 9:22 PM / IP Logged
Teken-
Thank you for the quick reply. You rock.
Wednesday, March 18, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
