Car not starting?
shesaidshewas18
Copper - Posts: 96
Posted: October 20, 2004 at 10:26 PM / IP Logged
The alarm is a Thor one, and the remote start feature wasnt installed. Only the keyless entry, shock sensor or whatever was installed. Not even the starter kill was installed. I used a DMM and checked the voltage on the ignition harness itself, and it read 6.XXX.. Any idea's on how to fix the car? The highbeams, horn, nothing is working, but the all the fuses are alright. I used my DMM to check the fuses also.
auex
Platinum - Posts: 5,041
Posted: October 20, 2004 at 11:07 PM / IP Logged
Have you checked the battery?
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
shesaidshewas18
Copper - Posts: 96
Posted: October 21, 2004 at 12:01 AM / IP Logged
Yes, it reads 12.xxx. We even tried to jump start it also
shesaidshewas18
Copper - Posts: 96
Posted: October 21, 2004 at 12:04 AM / IP Logged
Another thing, at the ignition switch the wire thats supposed to read 12v (white wire on a 98 Civic) reads only 6.xxx. While on the harness, like where the white wire leads to FROM the switch, reads only 10.xxx.
[battery = 12v]---------wires------------[harness = 10v]------------------wires--[ignition switch = 6v]
shesaidshewas18
Copper - Posts: 96
Posted: October 21, 2004 at 12:18 AM / IP Logged
Could the alarm possibly melt the wires? I also checked the wires from the ignition switch to the harness it plugs into, and those wires werent melted. But from the harness, to like the battery or whatever, could those be melted? The horn, headlights, nothing works however the battery still reads 12v?!
riceman
Copper - Posts: 109
Posted: October 21, 2004 at 12:24 PM / IP Logged
try cutting the insulation off and check for corroision on 12 volt wires this could cause a voltage drop.
Platinum - Posts: 12,488
Posted: October 21, 2004 at 1:40 PM / IP Logged
Did you check to see with a DMM the main fusable link in the fuse box in the engine ? Do not use a light tester or your eyes because it will not help you. Using a DMM will allow you to see if there is a problem with the fuse on both ends of the fusible link. Check all the fuses.
