89 Caprice Ignition Harness
northballer
Copper - Posts: 57
Posted: October 22, 2004 at 3:24 PM / IP Logged
I need to find the starter wire for this car but cant even find the ignition harness please help me thanks ps is there a way to find it without taking off the steering wheel or breaking the column thanks
SoundFX411
Copper - Posts: 153
Posted: October 22, 2004 at 3:37 PM / IP Logged
the starter is PURPLE and the ignition is   PINK
Both wires can be found at the ignition harness.
Remove the bottom cover under the dash and look for the harness comming out of the steering wheel
SoundFX
mo12v
Posted: October 22, 2004 at 3:38 PM / IP Logged
Harness is high on right side of steering column.  U do NOT have to break anything or pull the steering wheel.  (Not that it would help U )
Constant 12 voltsREDIGNITION SWITCH HARNESS
Ignition 12 voltsPINKIGNITION SWITCH HARNESS
StarterPURPLEIGNITION SWITCH HARNESS
Dome LightWHITE(-) AT PIN SWITCH
Trunk Pin SwitchDK GREEN (WAGON ONLY)(-) DRIVER KICK PANEL (2&4 DOOR N/A)
Parking LampBROWN(+) AT LIGHT SWITCH
Power LockLIGHT BLUEDRIVER KICK
Power UnlockBLACKPANEL
Positive Pulse Door Lock
Accessories
Window UpD\ D BLU P\ D BLU/WHT D\ D GRN P\ L GRN @ MAIN
Window DownF/ BRN F/ TAN R/ VIO R/ VIO/WHT SWITCH
Ign Key WarnLIGHT GREEN(-) STEERING COLUMN HARNESS
Trunk ReleaseBLACK(+) AT RELEASE SWITCH #231
OEM HornBLACK(-) STEERING COLUMN HARNESS
HeadlightsYELLOW(+) AT HEADLIGHT SWITCH
OEM Alarm ArmN/A
OEM Alarm DisarmN/A
Reversal Rest At Ground Power Window Circuit. Positive Pulse Trunk Release
Remote Start
Tach SignalWHITEAT DISTRIBUTOR *
Ignition #2ORANGEIGNITION SWITCH HARNESS
Ignition #3N/A
AccessoryBROWNIGNITION SWITCH HARNESS
Neutral SafetyORANGE / BLACKGEAR SELECT SWITCH
Brake LightWHITE OR YELLOW (+)(+) SWITCH AT BRAKE PEDAL
Reverse LightLIGHT GREEN (+)(+) GEAR SELECT SWITCH
Rear Window Defrost
* Some Models Are Carburated, Some Throttle Body Injected.
MO
northballer
Copper - Posts: 57
Posted: October 22, 2004 at 4:14 PM / IP Logged
How many wires are on the ignition harness total
mo12v
Posted: October 22, 2004 at 4:33 PM / IP Logged
The wires R up high on the steering wheel column.  U will see a metal rod that moves back & forth when U turn ignition switch.  Follow that rod down the column to the actual Ignition switch.
Ther R NO wires attached to your Key Switch in the column
MO
Thursday, January 29, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
