Owner of f150 97
BIkER1
Member - Posts: 15
Posted: October 24, 2004 at 7:02 PM / IP Logged
I will like to know if one of you has a F150 1997.If yes can you post the diagram of the fuses block with the detail wich fuses is for.I will like to have that when I check a fuse to know wich fuse is for the radio,the horn etc,etc
I bought the truck 3 weeks ago and the owner manual was not in the truck.,.
Thank You for your help.
live to ride
raydawg357
Silver - Posts: 769
Posted: October 26, 2004 at 8:43 AM / IP Logged
Check your fuses with a test light or a DMM.  You have two fuse boxes, one in the driver's compartment and one under the hood.  The fuse that is blown may not neccessarily be the radio fuse.
Do it right the first time
Monday, April 27, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
