1999 Volkswagen Getta GLS.
dunyamunya
Member - Posts: 10
Posted: October 29, 2004 at 2:07 PM / IP Logged
I have a 1999 Volkswagen Getta GLS and I am planning to install Remote Start and Alarm. Can someone give me the wiring diagram for the car with the colors, locations and +/-? Also, does this car have an immobilizer? If so, which bypass module would you advice on buying? Thanks in advance to all.
Andrew
boomer_106
Silver - Posts: 710
Posted: October 29, 2004 at 5:01 PM / IP Logged
Volkswagen
Jetta
1999-2002
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
RED / BLUE
IGNITION SWITCH HARNESS
Ignition  #1:
BLACK
Ignition #2:
BROWN / RED
IGNIITON SWITCH HANRESS
Ignition  #3:
N/A
Accessory:
BLACK/ RED
Brake  Light:
RED / BLACK
AT SWITCH ABOVE BRAKE PEDAL
Tach  Signal:
GREEN/ YELLOW
OR GREEN/ RED IN HARNESS, ENGINE FRONT
Parking Lights:
GRAY/TAN
OR GRAY/ORANGE & GRAY/VIOLET *
Headlights:
WHITE/ BLACK
AT HEADLIGHT SWITCH
OEM Alarm  Disarm:
SEE NOTE BELOW **
OEM Alarm  Arm:
Diesel  Glow Plug:
Clutch  Bypass Wire:
Notes:
 * This vehicle maybe be equipped with a transponder immobilizer system, Must use Universal Alarm Bypass Module part #2x402 where X can be any number.
Volkswagen
Jetta
1999-2002
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
RED
Starter  Kill:
RED / BLUE
Ignition  +12 Volts:
BLACK
Dome  Lights/Superv:
BROWN / WHITE (-)
OR BLUE/GRAY (-) AT ALARM MODULE
OEM Horn:
BLACK / YELLOW
AT 3-PIN PLUG BEHIND FUSE PANEL
Power  Lock:
YELLOW/BLUE (-)
IN DRIVER'S DOOR OR RED / BLUE IN DR. KICK
Power  Unlock:
DK. GREEN/ RED (-)
IN DRIVER'S DOOR OR RED / LT. GREEN ***
Trunk  Release:
GRAY
AT SWITCH IN GLOVE BOX
Alarm  Input Wire:
BROWN / WHITE (-)
Notes:
* Split Parking Light System - must use relays to isolate the circuits from each other. ** Alarm Disarms With Single Pulse To The Unlock Wire. *** Two Consecutive Pulses, Unlocks The Door.
dunyamunya
Member - Posts: 10
Posted: October 29, 2004 at 5:49 PM / IP Logged
Thank you very much for help, boomer
Andrew
