Mazda 3 door pins
gears
Posted: October 31, 2004 at 2:57 PM / IP Logged
Hi all
I am doing a car starter on a new Mazda 3 manual and everything is working, but I can not find the door pins. I have done a search and have 2 different wiring diagrams that tell were the wires are and what color. One says they are negative and the other says positive. Any help would be much appriciated.
mo12v
Posted: October 31, 2004 at 3:06 PM / IP Logged
Dome LightBLACK/ BLUE (-)PASSENGER KICK PANEL
MO
gears
Posted: October 31, 2004 at 8:08 PM / IP Logged
Hey thanks for the reply.
Have you done an install on mazda 3. I have found 4 BLACK/ blue wires in the passenger kick and non of them were them dome light. Is there anywere else that i can get the dome light wire.
Thanks again
audiopro111
Copper - Posts: 160
Posted: October 31, 2004 at 9:27 PM / IP Logged
drivers sill in harness going under driver seat door trigger blk/blu negative one of 2 and trunk trigger in same spot blk/red 1 of 2    also negative .
AudioPro111
