1994 Crown Victory door locks
lilwayne23
Member - Posts: 22
Posted: November 01, 2004 at 2:27 PM / IP Logged
i have installed a Tecvox TC-4182 alarm but i cant find the door lock wires any other place than the switch itself. I was needing info and sugesstions on how to hook this up. Everything else is working fine I just need to hook up the keyless entry. The alarm has a 6 wire harness for the locks. 1 unlock, 1 lock, 2 voltage inputs, and 2 grounds.
lilwayne
mo12v
Posted: November 01, 2004 at 2:41 PM / IP Logged
If you have Factory Keyless already, U will have to wire as 5 wire Reversal
Power LockPINK / YELLOWDRIVER KICK PANEL OR
Power UnlockPINK/LT GREENBEHIND GLOVE BOX **
** Without OEM Keyless - Reversal Rest At Ground Door Locks
   With OEM Keyless - Negative Pulse Door Locks
You can access at Door Boot also
MO
