2001 Dodge Ram Keyless Entry
scottrichie
Posted: November 04, 2004 at 7:39 PM / IP Logged
I am trying to hook up my Impulse IMP-4040.  Alarm, Remote Start, & Keyless Entry.  Everything is working but I don't seem to know how to hook up the keyless entry.  I know it is 5 wire reverse polarity.
I have one 451M, do I need two.  Also, are all of the wires I need located in the kick panel in the plug that leads into the door?  Also can the wires be found elsewhere?  Central Timer Module to the Right side of the steering wheel; If so what does this look like and where is it exactly?  About how many wires?
Thanks in advance for any help.
mo12v
Posted: November 04, 2004 at 10:39 PM / IP Logged
I usually wire at the Driver Kick panel
U can pop out the plug on outside door pillar and then Unplug plug and wire there.  Or if U like laying down, U can UnPlug inside kick panel.  I just can't get my FAT Girlie hands in there
Power LockORANGE / VIOLET16 PIN CONNECTOR IN DRIVER
Power UnlockPINK/VIOLETKICK PANEL
Reversal Rest At Ground Door Locks
MO
Sunday, April 5, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
