firewall help
robbys
Posted: November 05, 2004 at 2:41 PM / IP Logged
howxo i find a whole in a 1995 chevy blazer cuz  i been looking and there isnt anything i can runn a 4 gage wire through
audiobass10
Silver - Posts: 328
Posted: November 05, 2004 at 4:29 PM / IP Logged
All i can suggest is keep looking and if you still dont find one then drill one.
Dave
Pioneer Premier DEH-P660
15" Kicker CVR
Profile AP1000M
It's Loud
Jay T
Copper - Posts: 169
Posted: November 05, 2004 at 6:15 PM / IP Logged
Usually around the steering column.  Keep looking its there.  Look for a rubber grommet and remove that or trim it then feed the wire through
jeffchilcott
Platinum - Posts: 2,483
Posted: November 05, 2004 at 7:36 PM / IP Logged
be very very careful when driling though this vehicle lots of stuff against the fire wall that could be dammaged
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
sl00wsentra00
Member - Posts: 20
Posted: November 05, 2004 at 8:53 PM / IP Logged
if you could take a drill to the existing holes youve found and enlarge it if possible...im sure it could fit 4 gauge wire through there i thought mine couldn't but it did firewall help -- posted image.  just post with anymore questions!!!!!
lathan
Copper - Posts: 105
Posted: November 05, 2004 at 10:15 PM / IP Logged
what i do man, like 12 times a week when i drill a firewall is normally look for where the throttle cable comes through from above the accelerator. go back and fourth a couple times and be sure to look for safe clearance. good luck and peace...
Lathan Hites
"I'm sorry, without a credit card I'll be requiring a stool sample"
stevdart
Platinum - Posts: 5,816
Posted: November 05, 2004 at 10:32 PM / IP Logged
How I drill a hole, by stevdart:  ^^^everything they said.  Then use a small bit for the starter hole and feed a stiff wire through it until you see it extend out the other side.  Then you can pinpoint the area that would be best for drilling, if not the exact one you drilled.  (A small diameter bit has a proportionally lower chance of doing damage when you're mostly in the dark...and leaves less of a....well, hole....if it's not a good place.)
