neons w/ alarm question
patrickmhs02
Member - Posts: 6
Posted: November 06, 2004 at 7:33 PM / IP Logged
ive been reading various posts on how to hook my neon underbody kit to my alarm. i followed every diagram that i could find and tried all possiblities that i could. i was about to give up then i tried my own solution. i tapped into my parking lite, took that wire and tapped into the switch for my neons. it works (no relay) my neons also come on when i turn my headlights on and i also have a kill switch; just wondering if this will work permanetely or if it will do any damage??? also...
the installer that did my alarm did not install an led status lite; any suggestions on installing 1 myself or should i go back and get that done??
i have an audiovox pro 9842b alarm on a 94 mustang
daniel2002p
Silver - Posts: 524
Posted: November 07, 2004 at 9:31 AM / IP Logged
as far as neons, they are just fine, you factory systems is plenty strong to push them, as far as the led, make sure that the alarm first has  LED output.
2005 Toyota Corolla S
    1.8L VVT-i I-4
Always double check your wires with a DMM!!!
Do Not Use A Test Light!!!
MECP Certified Installer!
Best Buy 665 - IN IT TO WIN IT! TEAM MOBLE!
patrickmhs02
Member - Posts: 6
Posted: November 07, 2004 at 9:50 AM / IP Logged
thanx for the reply, it does have an output for an led stutus light but they just never installed one, why i don't know???
