2001 daewoo leganza door locks
cvrueda
Posted: November 06, 2004 at 9:17 PM / IP Logged
    • I need info on the 2001 leganza door locks.  I found the relay box in the kick panel, but i can't figure out if it's positive pulse/neg.pulse or reverse rest at ground.
tintpimp
mo12v
Posted: November 06, 2004 at 9:35 PM / IP Logged
Power LockLIGHT BLUE/WHITEDRIVER'S KICK PANEL
Power UnlockYELLOWDRIVER'S KICK PANEL
Negative Doorlock Circuit
MO
snguyen
Silver - Posts: 281
Daewoo
Leganza
1999-2002
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
RED / BLACK
IGNITION SWITCH HARNESS
Starter  Kill:
YELLOW
Ignition  +12 Volts:
RED / YELLOW
Dome  Lights/Superv:
WHITE (-)
DRIVER'S KICK PANEL BY FUSE BOX
OEM Horn:
Power  Lock:
BLUE/ (-)
GRAY RELAY BOX ABOVE FUSE BOX *
Power  Unlock:
GRAY/BLACK (+)
Trunk  Release:
Alarm  Input Wire:
WHITE (-)
Notes:
* Lock Wire Requires A Negative Pulse, Unlock Wire Requires A Positive Pulse.
snguyen
Silver - Posts: 281
Posted: November 06, 2004 at 9:41 PM / IP Logged
ItemWire ColorPolarityWire Location
12Vred & RED / black+ignition harness
STARTERyellow+ignition harness
IGNITIONRED / yellow+ignition harness
ACCESSORYRED / blue+ignition harness
SECOND ACCESSORYnone
TACHOMETERORANGE / blackignition coil
POWER LOCKblue/white *1-doorlock timer above fusebox
POWER UNLOCKyellow or gry/blk *1-doorlock timer above fusebox
PARKING LIGHTS +BROWN / whitedrivers kick panel
PARKING LIGHTS -whiteheadlight switch
DOOR TRIGGERwhite-drivers kick panel
HEADLIGHTS
WIPERS
LF WINDOW UP/DN
RF WINDOW UP/DN
LR WINDOW UP/DN
RR WINDOW UP/DN
TRUNK/HATCH PINpink/black-drivers kick panel
HOOD PIN
TRUNK/HATCH RELEASE
FACTORY ALARM ARM
FACTORY ALARM DISARM
HORN TRIGGER
BRAKE WIREblue+brake switch
LOCK MOTOR
UNLOCK MOTOR
DISARM DEFEAT
DISARM NO UNLOCK
DOME SUPERVISION
SPEED SENSE
SUN ROOF OPEN/CLOSE
SUN ROOF LIMIT
LF SPEAKER
RF SPEAKER
LR SPEAKER
RR SPEAKER
RADIO 12V
RADIO GROUND
RADIO SWITCH
RADIO ILLUMINATE
POWER ANTENNA
Notes:*1 Have to add actuator in the driver door if the vehicle does not have factory keyless entry.
cvrueda
Posted: November 07, 2004 at 9:13 PM / IP Logged
thanks you for your help....    The car did not have keyless entry, so the actuator worked perfect.
tintpimp
cvrueda
Posted: November 07, 2004 at 9:14 PM / IP Logged
actuator worked perfect....Thank you
tintpimp
