[B]1990 Toyota Tercel Tach wire[/B]
Welcome Guest :)
bush_666
Member -
Posted: November 08, 2004 at 9:46 PM / IP Logged
Hello people!!!
Is anyone know where tachometer wire can be found for 1990 Toyota Tercel (Carburator model) and what color is it? I need this to complete a remote starter installation.
Thank you in advance!!!!
![[B]1990 Toyota Tercel Tach wire[/B] -- posted image.](https://www.the12volt.com/installbay/smileys/smiley1.gif)
snguyen
Silver -
Posted: November 08, 2004 at 11:02 PM / IP Logged
| Item | Wire Color | Polarity | Wire Location |
| 12V | white | + | ignition harness |
| STARTER | BLACK/ white | + | ignition harness |
| IGNITION | BLACK / YELLOW | + | ignition harness |
| ACCESSORY | blue/red | + | ignition harness |
| SECOND ACCESSORY | BLACK/ red | + | ignition harness |
| TACHOMETER | black | | check connector |
| POWER LOCK | none | | |
| POWER UNLOCK | none | | |
| PARKING LIGHTS + | green | | 15 pin plug at fusebox |
| PARKING LIGHTS - | RED / white | | steering column |
| DOOR TRIGGER | RED / white | - | 15 pin plug at fusebox |
| HEADLIGHTS | RED / yellow | - | steering column |
| WIPERS | blu/blk & yel/blu | + | steering column |
| LF WINDOW UP/DN | none | | |
| RF WINDOW UP/DN | none | | |
| LR WINDOW UP/DN | none | | |
| RR WINDOW UP/DN | none | | |
| TRUNK/HATCH PIN | tied in with door *1 | | |
| HOOD PIN | pink/green | - | theft ECU *2 |
| TRUNK/HATCH RELEASE | none | | |
| FACTORY ALARM ARM | WHITE/ green | - | theft ECU *2 |
| FACTORY ALARM DISARM | WHITE/ blue | - | theft ECU *2 |
| HORN TRIGGER | GREEN/ YELLOW | - | steering column |
| BRAKE WIRE | GREEN / WHITE | + | brake switch |
| LOCK MOTOR | none | non | none |
| UNLOCK MOTOR | none | non | none |
| DISARM DEFEAT | none | non | none |
| DISARM NO UNLOCK | none | non | none |
| DOME SUPERVISION | none | non | none |
| SPEED SENSE | none | non | none |
| SUN ROOF OPEN/CLOSE | none | non | none |
| SUN ROOF LIMIT | none | non | none |
| LF SPEAKER | none | non | none |
| RF SPEAKER | none | non | none |
| LR SPEAKER | none | non | none |
| RR SPEAKER | none | non | none |
| RADIO 12V | none | non | none |
| RADIO GROUND | none | non | none |
| RADIO SWITCH | none | non | none |
| RADIO ILLUMINATE | none | non | none |
| POWER ANTENNA | none | non | none |
| Notes: | *1 Tied in with the door trigger only on the hatchback model. The sedan model does not have a trunk pin. *2 The theft ECU is located behind the radio and ashtray |
Thursday, May 14, 2026
• Copyright © 1999-2026 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
