Voice coils & amp wattage
Thuan
Copper - Posts: 88
Posted: November 09, 2004 at 2:09 AM / IP Logged
How can I tell if my voice coils are working properly? Also, how do I check to see how many watts my amp is putting out? Am I suppose to use a multi meter...if yes, then how am I suppse to check it with a multi meter?
Thuan
Thuan
Copper - Posts: 88
Posted: November 09, 2004 at 3:12 PM / IP Logged
anyone?
Thuan
DYohn
Moderator - Posts: 10,741
Posted: November 09, 2004 at 3:30 PM / IP Logged
What do you mean by "if my voice coils are working properly?"  Do your speakers work?
You cannot directly measure power output from your amplifier with a multimeter.  You can measure the AC voltage output and calculate the approximate effective average power by using the loudspeaker's average impedence and Ohm's law...
Thuan
Copper - Posts: 88
Posted: November 09, 2004 at 4:12 PM / IP Logged
I meant if one of my voice coils are burnt or not (subwoofer). Do I just hook it up and make sure there's continuity within each coil? I'm not sure if my amp is working properly so I want to check everything before I send it back for another one.
Ohm's law...E=IxR?...that would give me Voltage = Amperage x Resistance right? But how do I figure wattage from that?
Thuan
jeffchilcott
Platinum - Posts: 2,483
Posted: November 09, 2004 at 4:25 PM / IP Logged
If you take your amperage and mulitply it times you current draw you will get wattage
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
DYohn
Posted: November 09, 2004 at 4:37 PM / IP Logged
Yes, read the DC resistance on each voice coil with your ohm meter.  If the sub has two coils, they should both read about the same value.  If they do not, the one that is significantly higher is probably burned.
Power = Voltage squared / Resistance.  https://www.the12volt.com/ohm/ohmslaw.asp
Thuan
Copper - Posts: 88
Posted: November 09, 2004 at 4:59 PM / IP Logged
Thanks guys.
Thuan
Friday, May 10, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
