Wiring Diagram for 240SX
Escy
Member - Posts: 8
Posted: November 11, 2004 at 10:50 AM / IP Logged
Hi guys, i'm new here. i have a 200SX which is basically a UK version of the 240SX (but with a better engine!). i want to fit a clifford concept 500 alarm to it, and also get it working with my HKS type 1 turbo timer.
are there any wiring diagrams i can follow to make things easy?
this site looks really good by the way :)
Cheers, Tom.
another-kelly
Silver - Posts: 618
Posted: November 11, 2004 at 11:07 AM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - NISSAN / 200SX (UK) / 1995 / Remote Start
[PRINT THIS PAGE]
12volts
Starter BLACK / YELLOW    ignition harness
Second Starter
Ignition BLACK/ white    ignition harness
Second Ignition
Third Ignition
Accessory BLACK/ blue    ignition harness
Second Accessory
Keysense
Power Lock grey   -  CDL relay by steering column
Power Unlock violet/grey   -  CDL relay by steering column
Lock Motor
Unlock Motor
Parking Lights+ grn/yel & grn/blk   at the steering column
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger RED / white   -  driver kick panel
Dome Supervision
Trunk/Hatch Pin
Hood Pin
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm
Factory Alarm Disarm
Disarm No Unlock
Tachometer
Wait to start
Brake Wire white    brake pedal switch
Parking Brake
Horn Trigger
Memory Seat 1
Memory Seat 2
Memory Seat 3
Wiring Diagram for 240SX -- posted image.
Immobilizer Bypass Module: Not Available
another-kelly
Silver - Posts: 618
Posted: November 11, 2004 at 11:08 AM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - NISSAN / 200SX (UK) / 1990 / Remote Start
[PRINT THIS PAGE]
12volts
Second Starter
Ignition BLACK/ red    ignition harness
Second Ignition
Third Ignition
Accessory blue    ignition harness
Second Accessory
Keysense
Power Lock add actuator    in driver door
Power Unlock add actuator    in driver door
Lock Motor
Unlock Motor
Parking Lights+ grn/yel & grn/blk   above the o/s kick panel
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger RED / WHITE/ silver   -  at the interior light
Dome Supervision
Trunk/Hatch Pin
Hood Pin
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm
Disarm No Unlock
Tachometer
Wait to start
Parking Brake
Horn Trigger
Memory Seat 1
Memory Seat 2
Memory Seat 3
another-kelly
Silver - Posts: 618
Posted: November 11, 2004 at 11:09 AM / IP Logged
[PRINT THIS PAGE]
12volts
Second Starter
Second Ignition
Third Ignition
Second Accessory
Keysense
Lock Motor
Unlock Motor
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Dome Supervision
Trunk/Hatch Pin
Hood Pin
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm
Disarm No Unlock
Tachometer
Wait to start
Parking Brake
Horn Trigger
Memory Seat 1
Memory Seat 2
Memory Seat 3
another-kelly
Silver - Posts: 618
Posted: November 11, 2004 at 11:13 AM / IP Logged
danged re-post! anyway, '90 and '95 was all i had for 200SX. what year is yours and i can post a similar for the 240SX.
