1995 Pontiac Firebird
GregLewis
Posted: November 13, 2004 at 1:09 PM / IP Logged
I need wiring diagram for the 1995 Pontiac Firebird
greg
mo12v
Posted: November 13, 2004 at 6:42 PM / IP Logged
95 T/A
Constant 12 voltsREDIGNITION SWITCH HARNESS
Ignition 12 voltsPINKIGNITION SWITCH HARNESS
StarterYELLOWIGNITION SWITCH HARNESS
Dome LightWHITEUNDER DASH COURTESY LIGHT OR PIN SW.
Trunk Pin SwitchBLACK/ ORANGE (-)REAR HATCH PIN SWITCH OR DOME LIGHT**
Parking LampBROWN(+) AT HEADLIGHT SWITCH
Power LockLIGHT BLUEDRIVER KICK PANEL
Power UnlockDARK BLUEBEHIND INSULATION *
* If Equipped With OEM Keyless Entry: Lock- RED / BLACK, Unlock- ORANGE / BLACK At Keyless Entry Module In Passenger Kick Panel. Passenger Switch Is Primary Switch!!
Reversal Rest At Ground Door Locks.
** This Wire Will Catch All Three Doors. Check For Dome Light Harness Behind Driver Rear Speaker.
Accessories
Window UpD\ D BLU P\ L BLU @ MAIN SWITCH
Window DownR/ BRN S/ TAN
Ign Key WarnLIGHT GREEN (-)KEY WARNING SWITCH (STEERING COLUMN)
Trunk ReleaseBLACK (+)RELEASE SW. OR DRIVER KICK PANEL
OEM HornBLACK (-)STEERING COLUMN HARNESS OR AT RELAY
HeadlightsYELLOW (+)HEADLIGHT SWITCH OR BEAM SELECT SW.
OEM Alarm ArmN/A
OEM Alarm DisarmN/A
Reversal Rest At Ground Power Window Circuit Diagram.
Positive Pulse Trunk Release
Remote Start
Tach SignalWHITE(V6)AT DISTRIBUTOR,(V8) AT COIL
Ignition #2ORANGEIGNITION SWITCH HARNESS
Ignition #3N/A
AccessoryBROWNIGNITION SWITCH HARNESS
Neutral SafetyORANGE / BLACK (-)GEAR SELECT SWITCH AT BASE OF SHIFTER
Brake LightYELLOW OR L BLUE (+)AT SWITCH ON BRAKE PEDAL BRACKET
Reverse LightLIGHT GREEN (+)GEAR SELECT SWITCH AT BASE OF SHIFTER
Rear Window Defrost
VATS System Standard On 1995 Models
MO
Tuesday, March 17, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
