Ford OEM Alarm help
hrly6816
Posted: November 19, 2004 at 7:12 PM / IP Logged
I am having a problem with my Ford OEM Dealer installed alarm.  I have a 2002 F150 with the Ford Series 3 or maybe 4 alarm.(Manual says series 3 and 4)  A few weeks ago I had my battery disconnected to install a brake controller for my trailer.  When I hooked the battery back up the alarm went off.  I tried to use the remote but that did not work.  I had to hit the little button under the dash and turn my key on to get it to stop.
Now for the problem:
The alarm will arm with the remotes or the door lock switch, but it will not disarm.  As soon as I hit the unlock button on the remote the alarm sounds.  I had to put the alarm into valet mode to stop it from going off every time I unlock my truck.  Is there any way to reprogram the alarm?  Everything was working perfect until I disconnected the battrey.  I have called 10 different dealers and not of them will touch it.
daniel2002p
Silver - Posts: 524
Posted: November 19, 2004 at 11:02 PM / IP Logged
is that a original facotry alarm, or a dealer installed alarm?
2005 Toyota Corolla S
    1.8L VVT-i I-4
Always double check your wires with a DMM!!!
Do Not Use A Test Light!!!
MECP Certified Installer!
Best Buy 665 - IN IT TO WIN IT! TEAM MOBLE!
hrly6816
Posted: November 20, 2004 at 7:27 AM / IP Logged
It is a dealer installed Ford Alarm.
TimothyCox
Member - Posts: 7
Posted: November 20, 2004 at 10:47 PM / IP Logged
You need a real tech, not a dealer. These things scare them away.
Reply to this post with your city/state, hopefully someone monitoring this board is near you and can help.
If in MA, I may be able to help, I love a good challenge!
Tim
daniel2002p
Silver - Posts: 524
Posted: November 21, 2004 at 1:54 PM / IP Logged
Can you locate the alarm under the dash and see what brand it is????
    1.8L VVT-i I-4
rjaykay
Posted: November 21, 2004 at 8:35 PM / IP Logged
Howdy All,
I am New to this forum, with a similar problem, I just replaced my blower motor in my 1997 E250 cargo van, I bought this van used and it has what seems like a factory installed alarm, well when i reconnected the battery the alarm sounded for the first time in at least 3 years as I have neverused it, a friend showed me how to turn it off by turning the key on and pressing the button under dash, I would like to ask, What would I have to do to get an alarm activator / deactivator, Is it possible that there is a remote starter and / or automatic door locks and how could I tell?
Thank You All,
Robert
rjk
hrly6816
Posted: November 22, 2004 at 10:20 AM / IP Logged
It says FORD Vehicle Secuity System on the Brain.  There are 3 plugs.
1 goes to the siren 2 wires.
1 goes to the starter disable.  4 wires.
1 goes to everything else  looks like 18 to 25 wires.
rocksound
Member - Posts: 7
Posted: November 22, 2004 at 7:54 PM / IP Logged
plug out main harness for 15 seconds and reconnect. if same problem exists, there are 3 wires that go to the door locks.  pink is your arming wire it goes to a pink/black yellow is  your sense wire it goes to pink/orange. brown is your disarm wire this goes to RED / orange. I hope this helps. GARY
