Subaru 2000 WRX wiring Diagram
Welcome Guest :)
quacka
Member -
Posted: November 22, 2004 at 11:41 PM / IP Logged
Hi,
I am looking for the subaru 2000 WRX wiring diagram. I found the subaru impreza 2000 in teh database. Does that apply to the WRX too or only the standard impreza?
rudbwoy69camaro
Silver -
Posted: November 27, 2004 at 3:50 PM / IP Logged
They are the same car, in some respects
2000 Subaru Impreza
| Item | Wire Color | Polarity | Wire Location |
| 12V | white | + | ignition harness |
| STARTER | WHITE/ black | + | ignition harness |
| IGNITION | green | + | ignition harness |
| ACCESSORY | yellow | + | ignition harness |
| SECOND ACCESSORY | none | | |
| TACHOMETER | blue or RED / green | | ignition coil *3 |
| POWER LOCK | blue/green | - | keyless module *1 |
| POWER UNLOCK | yellow/red | - | keyless module *1 |
| PARKING LIGHTS + | orange | | parking light switch |
| PARKING LIGHTS - | BLACK/ white | | headlight switch |
| DOOR TRIGGER | yellow | - | keyless module *1 |
| HEADLIGHTS | green | - | headlight switch |
| WIPERS | blk/blu & RED / blu | + | steering column |
| LF WINDOW UP/DN | blue - blu/red | A | drivers window switch |
| RF WINDOW UP/DN | RED / blu - blk/blu | A | drivers kick panel |
| LR WINDOW UP/DN | blu/yel - grn/yel | A | drivers kick panel |
| RR WINDOW UP/DN | blu/wht - grn/wht | A | drivers kick panel |
| TRUNK/HATCH PIN | yellow/blue | - | trunk light |
| HOOD PIN | none | | |
| TRUNK/HATCH RELEASE | none | | |
| FACTORY ALARM ARM | none | | |
| FACTORY ALARM DISARM | none | | |
| HORN TRIGGER | RED / green | - | steering column |
| BRAKE WIRE | WHITE/ black | + | brake pedal switch |
| LOCK MOTOR | lt. GREEN/ black | | door lock timer *2 |
| UNLOCK MOTOR | blue/white | | keyless module *1 |
| DISARM DEFEAT | RED / green | | door lock timer *2 |
| DISARM NO UNLOCK | none | | |
| DOME SUPERVISION | use door trigger | | |
| SPEED SENSE | GREEN/ YELLOW | | instrument cluster or *4 |
| SUN ROOF OPEN/CLOSE | yel/red - yellow | A | sunroof motor |
| SUN ROOF LIMIT | none | | |
| LF SPEAKER | brn/wht - green | | radio |
| RF SPEAKER | RED / yel - wht/blk | | radio |
| LR SPEAKER | RED / blk - wht/red | | radio |
| RR SPEAKER | RED / wht - blu/yel | | radio |
| RADIO 12V | blue/red | + | radio |
| RADIO GROUND | black | - | radio |
| RADIO SWITCH | YELLOW /GREEN | + | radio |
| RADIO ILLUMINATE | WHITE/ yellow | + | radio |
| POWER ANTENNA | none | | |
| Notes: | *1 The keyless module is to the left of the steering column. *2 The door lock timer is up high above the drivers kick panel. It has a 6 pin plug. *3 The ignition coil is on the top of the motor on the passenger side. *4 Also found at the cruise control unit in the drivers kick panel. It has a 20 pin plug. |
Sunday, May 3, 2026
• Copyright © 1999-2026 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
