wire diagram for mustang
delsol4me
Posted: October 11, 2002 at 8:29 AM / IP Logged
Does anyone know where I can get the wiring diagram for a 96 mustang? I am going to attempt to install an alarm with remote start and a few other bells and whistles... Don't want to spend boku buck for the shop to do it. Please email me with suggestions at delsol4me@cs.com. Thanks alot!
Platinum - Posts: 12,488
Posted: October 11, 2002 at 9:21 AM / IP Logged
|              12V|yellow              |+  |ignition harness            |
|          STARTER|WHITE/ pink          |+  |ignition harness            |
|         IGNITION|tan/white           |+  |ignition harness            |
|  SECOND IGNITION|                    |   |                            |
|        ACCESSORY|gray / YELLOW         |+  |ignition harness            |
| SECOND ACCESSORY|BLACK/ lt. green     |+  |ignition harness            |
|       POWER LOCK|pink / YELLOW         |*1 |either kick panel           |
|     POWER UNLOCK|pink/green          |*1 |either kick panel           |
| PARKING LIGHTS +|brown               |   |driver kick panel           |
| PARKING LIGHTS -|                    |   |                            |
|       HEADLIGHTS|yellow/red          |+  |at light switch             |
|     DOOR TRIGGER|gray or blu/org*4   |+/-|either kick panel           |
|  TRUNK/HATCH PIN|tan/light green     |-  |*4                          |
|TRNK/HTCH RELEASE|purple / YELLOW       |+  |driver kick or switch       |
|  FCTRY ALARM ARM|                    |   |                            |
|FCTRY ALRM DISARM|dark GREEN/ purple   |-  |driver kick or *4           |
|       TACHOMETER|*2                  |   |*2                          |
|      SPEED SENSE|gray/black          |8  |PCM *5                      |
|       BRAKE WIRE|RED / lt. green      |+  |brake switch                |
|     HORN TRIGGER|yel/lt. green       |-  |steering column or*4        |
|           WIPERS|                    |   |                            |
|  LF WINDOW UP/DN|red - yellow*3      |A  |in drivers door*3           |
|  RF WINDOW UP/DN|yellow/red - RED / yel|A  |drivers kick panel          |
|  LR WINDOW UP/DN|                    |   |                            |
|  RR WINDOW UP/DN|                    |   |                            |
Notes:
NOTE:  Some models of this vehicle are equipped with PATS (Passive Anti Theft System).  *1 Non-keyless versions are 5-wire and the keyless versions are negative pulse.  *2 3.8 liter find coil pack at top front of engine. Use tan/white, tan/orange or tan/light green, use two cylinder setting. 4.6 liter SOHC and 4.6 liter DOHC, two coils at top front of engine. Use RED / yellow, pink/white, RED / light blue or dark blue/light blue, two cylinder setting.  *3 Be sure to use wire going directly to motor. On touch module located bottom, rear of drivers door.  *4 Anti Theft Control Unit located left rear of trunk behind trim panel.  *5  PCM is in the passenger kick.
