friend has system problem
audiobass10
Silver - Posts: 328
Posted: November 23, 2004 at 12:43 PM / IP Logged
A friend of mine is having an odd problem of his bass going out whenever the car comes to a complete stop...could it be because his subs are being run off his stock amplifier?..its a 97 lincon continental and i know it sounds wierd but i promise he's runnin 2 mtx 10's off of it and really hasn't had any problems till now. So anyone know of problems like this?
Dave
Pioneer Premier DEH-P660
15" Kicker CVR
Profile AP1000M
It's Loud
dxav
Silver - Posts: 314
Posted: November 23, 2004 at 1:07 PM / IP Logged
The bass goes 'out'? Does this mean the amp shuts off? How does the wiring look? Have you checked the ground wire? Does the bass come back after sitting at a stop, or does he have to start moving again? Your connections maybe loose somewhere......
That must be one heckuva amp!
DXAV
audiobass10
Silver - Posts: 328
Posted: November 23, 2004 at 3:44 PM / IP Logged
I personally haven't taken a look at his stuff yet..he tells me when hes at a complete stop..there is no bass..but when he starts moving again it starts back up..wierd..i need to take a look at it but keep the replies coming.
Dave
15" Kicker CVR
Profile AP1000M
It's Loud
DYohn
Platinum - Posts: 10,741
Posted: November 23, 2004 at 3:55 PM / IP Logged
Check to see if the alternator belt has gone bad.  Or maybe the alternator is dying.  When a car is idling, an alternator puts out minimal voltage.  When an engine speeds up, the alternator voltage output goes up.  Could be the amp is shutting down on low voltage.  Next time he is stopped and the bass "goes out," put the car in neutral and rev the engine.  If it comes back on, I'll bet you a nickel it's either a bad alternator, bad voltage regulator, or bad belt.
audiobass10
Silver - Posts: 328
Posted: November 23, 2004 at 4:11 PM / IP Logged
It's def. not an alternator problem because he just replaced it maybe 2 months ago. As for the alternator belt..i dont even know where thats located or how to check if its gone bad..but i'm guessing with a new alternator it hasn't..could it be the low power the amp puts out is not enough to run the subs at low voltage..although he's been running them fine until now. Maybe it just started to crap out?
Dave
15" Kicker CVR
Profile AP1000M
It's Loud
heavilymedicate
Silver - Posts: 328
Posted: November 23, 2004 at 4:15 PM / IP Logged
I was thinking the same thing DYohn was.  Try reving the engine to like 3000 rpm and holding it, see if comes back on standing still.
What will you get for Christmas, bad boy? Coal........or Visonik?? - stevdart
Wow, is everyone clueless and lost in the dark? - uthinkuknoaudio
audiobass10
Silver - Posts: 328
Posted: November 23, 2004 at 7:33 PM / IP Logged
Alright...bass works fine now? Dont know why..he's not running the subs off the factory amp..i knew that sounded wierd..he told me while the bass was doin that..his keyless entry wouldnt beep either...i have no clue what went wrong but it seems ok as of now..
Dave
15" Kicker CVR
Profile AP1000M
It's Loud
