2003 Honda Jazz Alarm
quacka
Member - Posts: 7
Posted: November 24, 2004 at 10:26 PM / IP Logged
Hi,
I need the wiring diagram for 2003 Honda Jazz to install an alarm my girlfriends car. Anyone have one handy?
quacka
Member - Posts: 7
Posted: January 07, 2005 at 7:00 AM / IP Logged
Hi,
I am trying to find the power lock and tach sensor to install my alarm.
I assume to test the tach cable i plug meter to +ve and black to the tach cable and the voltage should rise if I accelerate
I cannot find the Power lock at all.
Correct me if i am wrong. To test for this cable. This cable should be connected to the -ve of the multimeter and the +ve multimeter connects to a constant 12V. When i unlock or lock teh door this cable should show 12V on the multimeter
jaurora
Silver - Posts: 429
Posted: January 07, 2005 at 7:13 AM / IP Logged
1) To test for tack wire set your multimeter to AC volts. Depending on the vehilce you should see between 0-5volts, 0 being @ idle 5 or someties higher at higher RPM.
2) There are a few different types of doorlock systems. Check here.  https://www.the12volt.com/doorlocks/doorlocks.asp
MECP certified (If it really means anything)
Jeremy
quacka
Member - Posts: 7
Posted: January 08, 2005 at 3:37 AM / IP Logged
Hi,
Can anyone tell me where this cable is on teh Honda Jazz/Fit. They are normally easy to find but cant seem to find it on this car.
quacka
Member - Posts: 7
Posted: January 08, 2005 at 7:16 AM / IP Logged
Oh I forgot. I got the wiring Diagram for the 2003 honda jazz fit which has the Central Lokcing system in it. It can be located here. I cant find what wire i need to to trigger as a power lock and unlock though. Can soem one help me?
http://www.qfl.com.au/alarm.zip
quacka
Member - Posts: 7
Posted: January 08, 2005 at 7:17 AM / IP Logged
sorry there is a link for quicker access
quacka
Member - Posts: 7
Posted: January 08, 2005 at 3:50 PM / IP Logged
A small car like civic only in Australia and Uk at the moment i think
Thursday, February 19, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
