This work or not? Cold Heat Tool
Yuri
Member - Posts: 8
Posted: December 02, 2004 at 10:54 AM / IP Logged
I've had professional solder training as well. But I have another thought on possible uses of this product.
Having been away from civilization many times with just a handfull of Jeeps, something like this tool may come in handy some day. Granted, I've never tried this tool. But cold solder joint or not... if it works enough to get my Jeep off the trail, it is worth the $20. The cold joint can always be redone correctly when I get home. A regular soldering iron can be a pain in cases like this because it takes a while to get hot, and a while to cool down.
Realistically, a butane iron probably works better than this "cold heat" thing. And I will continue wheelin' with the butane in my tool bag.
flynntech
Copper - Posts: 275
Posted: December 02, 2004 at 6:25 PM / IP Logged
That $20 is best spent on some beef jerky and beer, the butane torch is all you need to fix a wire.
Friday, January 2, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
