97 Isuzu Rodeo Tach wire
Rick1982
Member - Posts: 6
Posted: November 27, 2004 at 12:17 PM / IP Logged
Can someone please help me locate the tach wire for a 97 rodeo? The diagram says yellow wire in multi coil pack but I am still having trouble. This is the only wire I have left to find.
rudbwoy69camaro
Silver - Posts: 350
Posted: November 27, 2004 at 5:43 PM / IP Logged
1997 Isuzu Rodeo
ItemWire ColorPolarityWire Location
12VWHITE/ black+ignition harness
STARTERBLACK/ white+ignition harness
IGNITIONBLACK / YELLOW+ignition harness
ACCESSORYblue+ignition harness
SECOND ACCESSORYBLACK/ red+ignition harness
TACHOMETER*1*1
POWER LOCKlt. GREEN/ red-drivers kick panel *2
POWER UNLOCKRED / white-drivers kick panel *2
PARKING LIGHTS +GREEN/ reddrivers kick panel
PARKING LIGHTS -GREEN/ YELLOWsteering column
DOOR TRIGGERRED / green-drivers kick panel
HEADLIGHTSRED / blue-steering column
WIPERS
LF WINDOW UP/DNbrn/wht - blu/redAin drivers door
RF WINDOW UP/DNbrn/wht - blu/redAin R. F. door
LR WINDOW UP/DNbrn/wht - blu/redAin L. R. door
RR WINDOW UP/DNbrn/wht - blu/redAin R. R. door
TRUNK/HATCH PINlt. green-*3
HOOD PIN
TRUNK/HATCH RELEASEgray or RED / blue+at switch in dash
FACTORY ALARM ARM
FACTORY ALARM DISARM
HORN TRIGGERgreen or orn/blk-steering column *4
BRAKE WIREred+brake switch
LOCK MOTORnonenonnone
UNLOCK MOTORnonenonnone
DISARM DEFEATnonenonnone
DISARM NO UNLOCKnonenonnone
DOME SUPERVISIONnonenonnone
SPEED SENSEnonenonnone
SUN ROOF OPEN/CLOSEnonenonnone
SUN ROOF LIMITnonenonnone
LF SPEAKERnonenonnone
RF SPEAKERnonenonnone
LR SPEAKERnonenonnone
RR SPEAKERnonenonnone
RADIO 12Vnonenonnone
RADIO GROUNDnonenonnone
RADIO SWITCHnonenonnone
RADIO ILLUMINATEnonenonnone
POWER ANTENNAnonenonnone
Notes:*1 This vehicle has six coils each mounted on top of the spark plugs. The negative side of each coil is a green wire with stripe. GREEN/ black, GREEN / WHITE, GREEN/ orange, solid green, GREEN/ red, GREEN / WHITE. Use one wire and set module to one cylinder setting. *2 In a white plug in the lower drivers kick. this plug is for a dealer installed alarm and is not connected unless there is an alarm in the vehicle. When metering the wires, have to use the passenger door lock switch. *3 Behind left rear side panel at the rear wiper diode. *4 Located in the yellow air-bag wiring harness. Use caution when working with this harness, and test the wire with a digital multi-meter with a high internal resistance. Testing the incorrect wire with ANY other testing instrument will deploy the air-bag.
Rick1982
Member - Posts: 6
Posted: November 27, 2004 at 10:09 PM / IP Logged
thanks so much!!! very helpful
Monday, February 16, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
