$10 first to answer door lock?
jc9995
Member - Posts: 14
Posted: November 27, 2004 at 4:47 PM / IP Logged
 I too will paypal the first to answer this.
I have a factory keyless entry system. I purchased a remote starter that integrates with a factory keyless entry system. untilizing your factory remotes, and installing the remote starter properly, the starter sees 3 pulses from the door lock wire(pressing the remote lock button 3 times) then starts the remote start sequence. The remote starter did not come with remotes. I need to send it a negative signal 3 times in order for it to work. Since I dont know how to GET a signal from a single wire lock system, thats where my problem is.
Platinum - Posts: 12,488
Posted: November 27, 2004 at 4:51 PM / IP Logged
What vehicle is this for ? A Chrysler or a GM ? As long as you get a (-) signal from the single wire by pressing the LOCK button 3 times in a row, the remote starter will work. It doesn't have to be separated for the remote start to distinguish between the lock and unlock because it requires 3 pulses. Wire up the single wire lock/unlock to the activation wire of the remote starter and it should work.
jc9995
Member - Posts: 14
Posted: November 27, 2004 at 4:55 PM / IP Logged
it is on an 04 dodge ram. I will try this, thanks. If it works your $10 richer.
snguyen
Silver - Posts: 281
Posted: November 27, 2004 at 5:21 PM / IP Logged
JC9995,  If this works both draaach and velocity should get the $10.   I notice you had  post  this twice and draach answer on the other one and velocity answer on this one! $10 first to answer door lock? -- posted image.
auex
Platinum - Posts: 5,041
Posted: November 27, 2004 at 5:22 PM / IP Logged
If it doesn't then you can always tag the lock motor wire and use a relay to convert it from positive to negative. The lock motor wire is lt. green in the white plug in the driver's kickpanel. Then use this diagram.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
jc9995
Member - Posts: 14
Posted: November 27, 2004 at 5:27 PM / IP Logged
I will look into this. So far nothing else has worked. Are you sure it would be in the drivers kickpanel? or in the drivers door? This may be my only option. Also, looks as though Velocity, If this had worked, beet out Draach by 1 minute. $10 first to answer door lock? -- posted image.
auex
Posted: November 27, 2004 at 5:30 PM / IP Logged
It will be in the driver's kickpanel in the harness going into the door. It will also be in a large white plug under the main junction box to the left of the brake/clutch pedal.
draasch
Gold - Posts: 2,172
Posted: November 27, 2004 at 5:33 PM / IP Logged
jeff is already RICH! he doesnt need the money....he said he would donate the money to his favorite charity....ME! lol lol lol
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
jc9995
Member - Posts: 14
Posted: November 27, 2004 at 11:11 PM / IP Logged
Wel folks we have a winner! auex not only told me how to do it, but gave me the location and wire color to boot! Hopefully he will be sending me his email address soon so I can keep my word. Thanks to all for your help. I really appreciate your time!
forbidden
Platinum - Posts: 5,354
Posted: November 28, 2004 at 2:07 AM / IP Logged
Damn, where was I when this was going on. $10 first to answer door lock? -- posted image.
