2004 ford escape xlt remote start
jlo6
Posted: November 30, 2004 at 6:12 PM / IP Logged
 i need wiring info for a remote start. it has factory security.  thanks
CruisinS&S
Copper - Posts: 225
Posted: November 30, 2004 at 6:22 PM / IP Logged
12volts      RED / lt. blue (10A)       +       ignition harness
Starter      tan/lt. blue       +       ignition harness
Second Starter      N/A
Ignition      lt. GREEN/ purple       +       ignition harness
Second Ignition      N/A
Third Ignition      N/A
Accessory      BLACK/ lt. green       +       ignition harness
Second Accessory      N/A
Keysense      BLACK/ pink       +       ign harn or GEM, 22 pin plug, pin 6
Notes: The GEM (Generic Electronic Module) is behind the center console on the floor. Pull off the black panel to the right of the gas pedal, there will be carpet covering it. The plugs face the driver side of the vehicle.
Power Lock      pink/white       -       DKP or GEM, 26 pin plug, pin 23
Notes: Lock is negative trigger thru a 1,000 ohm resistor. Unlock is a straight negative trigger. MUST use relays.
Power Unlock      same wire as power lock
Lock Motor      pink/black       5wi      DKP or GEM, 26 pin plug, pin 13
Unlock Motor      RED / orange       5wi      DKP or GEM, 26 pin plug, pin 25
Parking Lights+      brown       +       driver kick, harness to rear
Parking Lights-      BLACK/ lt. green       -       switch or GEM, 22 pin plug, pin 4
Hazards      WHITE/ red       -       switch or GEM, 22 pin plug, pin 9
Turn Signal(L)      ORANGE / black       +       steering column
Turn Signal(R)      BROWN / white       +       steering column
Reverse Light      BLACK/ pink       -       driver kick, harness to rear
Door Trigger      PURPLE / lt. green       -       cluster or GEM, 22 pin plug, pin 10
Dome Supervision      lt. GREEN/ orange       -       dome lt or GEM, 26 pin plug, pin 1
Trunk/Hatch Pin      common with door trigger
Hood Pin      PURPLE / orange       -       pin sw or GEM, 22 pin plug, pin 16
Trunk/Hatch Release      N/A
Power Sliding Door      N/A
Factory Alarm Arm      WHITE/ purple       -       DKP or GEM, 26 pin plug, pin 20
Factory Alarm Disarm      dk. blue/lt. green       -       DKP or GEM, 26 pin plug, pin 19
Disarm No Unlock      see factory alarm disarm
Tachometer      NOT WHITE/ purple or red       ac       any ignition coil or fuel injector
Wait to start      N/A
Brake Wire      lt. green       +       brake pedal switch
Parking Brake      lt. GREEN/ red       -       parking brake switch
Horn Trigger      YELLOW /GREEN       -       column or GEM, 22 pin plug, pin 19
Memory Seat 1      N/A
Memory Seat 2      N/A
Memory Seat 3      N/A
Immobilizer Bypass Module:      Required: Yes      Type: SecuriLock      Part #: 555S, 556U, or 555U
Notes: Use the BLACK/ pink (+) key sense wire at the ignition harness to interrupt the blue wire on the 555S or 555U so that when the key is inserted to do take over the vehicle does not see two transponders at the same time. Refer to DirectFax document 1079 for wiring information.
Cruisin Security And Sounds
Saturday, May 18, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
