2001 ford f150 alarm/remote start
sport2001l
Member - Posts: 9
Posted: November 30, 2004 at 8:38 PM / IP Logged
i have a 2001 ford f150, with a DirectStart Cs423. i am trying to hook up the alarm on it. I need to find out what wire to hook up to catch the door triggers?? it needs to be a  - input or  i need help to convert it to a negative input.  are the door triggers - or +      thanks
Bnluis
Silver - Posts: 578
Posted: November 30, 2004 at 9:02 PM / IP Logged
DOOR TRIGGER|blk/yel & blk/pnk   |-  |*5
5 The BLACK / YELLOW catches the drivers door and the BLACK/ pink catches the passengers door. The wires are found in there respective door harnesses. On the Super Crew the rear door trigger is BLACK/ lt. blue low in the driver kick panel. Use all wires and diode isolate each. See direct fax document #1076 for wiring information. Both wires may also be found at the GEM module located above the fuse box. On models without a dome light delay use ORANGE / lt. green (-) at the light switch.
Luis
Sound Waves
Is up to the installer to test all wires with a DMM whenever possible.
Sunday, February 15, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
