2004 Jeep Grand Cherokee alarm
meh66
Copper - Posts: 266
Posted: December 04, 2004 at 5:30 AM / IP Logged
I have read all the post on this vehicle, but just to have things clear in my mind ,I wanted to ask for any and all help. I plan on using a CS-2011 and the door lock module that contains the immobolizer by-pass since the vehicle has a grey key, the number eludes me at the moment.
MEH66
"Car Performance and Mobile Electronic Enthusiats"
mxxmikexx
Silver - Posts: 796
Posted: December 04, 2004 at 6:44 PM / IP Logged
this vehicle is very easy, hardest part is getting access to the ignition harness, simplest way ive found is snaking your hand up there and just unplug the entire harness by the key switch and pulling it down so you can tag your wires. and a quick trick to save some time instead of wiring up resistors for the negative parking lites, just grab the negative hazard lite wire at the steering column instead. the brake wire can be a pain to get to sometimes, ive found just grabbing it in the kick panel is the easiest. hope this helps!
meh66
Copper - Posts: 266
Posted: December 05, 2004 at 8:54 AM / IP Logged
thanks mxxmikexx....
I have another concern, my friend told me that he talked to circuit city and they told him for this vehicle he could not use a combo system. Meaning a system with an alarm and remote start.  Initially, I said that statement makes no sense, but you never know. Do anyone know if this statement is true? His vehicle has no alarm but a RKE.
MEH66
mxxmikexx
Silver - Posts: 796
Posted: December 05, 2004 at 3:13 PM / IP Logged
your friends first mistake was going to circuit city. if they cant manage to install an alarm on that vehicle, thats not saying much for them. that statement is not true
