locks wont work .... acura legend
ecstasyroll
Member - Posts: 9
Posted: October 14, 2002 at 1:46 PM / IP Logged
as usual everything started good locks wont work .... acura legend -- posted image..... then "couple" of my cables where disconnected do to interior change and supposedly "reconnected" back causing couple of problems. one my started stopped working and second when locking doors with remote or manually (from inside) my locks start to CLICK and MOVE half way down but not locking all the way.   It keeps doing for about 2 min and then most of the time they lock sometimes they dont.
i have 91 acura legend 4 door.....i looked thru diagrams and im guessing my locking system isnt 2-pulse but i can be wrong if someone knows better.....the brand name of alarm i dont know but i know its made by DEI or one of its under-company.
thanks alot
alex
Ohmz
Copper - Posts: 193
Posted: October 14, 2002 at 5:58 PM / IP Logged
Does your door locks work normal with the switches in the vehicle?
moshe
Member - Posts: 26
Posted: October 14, 2002 at 6:12 PM / IP Logged
i think your car batteri low try to boost the bat
Ohmz
Copper - Posts: 193
Posted: October 14, 2002 at 10:12 PM / IP Logged
I misread you the 1ST  time Alex. Sounds like there is a loss of power. What do you mean, the remote start woudn't work?
Your car doesn't have 2 pulse locking sytem. If this is a DEI remote start there are many fuses by the relays that are attached to the brain. Check all your fuses. Make sure the alarm is getting a good ground.
ecstasyroll
Member - Posts: 9
Posted: October 18, 2002 at 6:01 PM / IP Logged
thanks but...
started doesnt work period...so im guessing couple of cables werent connected but i dont worry about that i can live without it....
locks when locked normally from the inside do the same thing they TRY to close but fail and then it just either gives up or locks
ill check fuses...:)
thanks
Sunday, July 20, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
