'01 Ford Ranger door triggers
LarryP
Member - Posts: 6
Posted: October 14, 2002 at 5:16 PM / IP Logged
 Hello,
I am installing an after-market alarm in my Ford Ranger. This alarm has  positive and a negative door trigger wires. I need to know if I will be using the + or - trigger wire on the alarm? Also, what color wire (and where is it located?) should I be using on the Ranger to tie into that will trigger my alarm when the dome light goes on when the doors open? (So that when my door opens the dome light will go on  it will send a trigger to my alarm)  Does the alarm wire need a diode after tying into the dome light?
Thanks again if anyone can help,
Larry
securinu
Silver - Posts: 772
Posted: October 14, 2002 at 6:00 PM / IP Logged
BLACK/ blue   +  at light under dash . so use the positive wire from alarm with no diode.
Monday, July 21, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
