02 Dodge Intrepid Alarm/Remote Start Wiring
Welcome Guest :)
nsidoine
Member -
Posted: December 08, 2004 at 10:29 PM / IP Logged
Hello,
I am looking for the wiring Diagram of my 2002 Dodge Intrepid in order to intall a remote starter/Alarm/keyless entry. I looked through everything on the site and could not find anything. Could somebody help me please???? I am really desperate........please.....
N. Naman
cerickso
Member -
Posted: December 09, 2004 at 8:44 AM / IP Logged
This should help.
To print: Click here or Select File and then Print from your browser's menuTo close this window: Click here or click the X at the top right of this window.DesignTech International, Inc. - Web Support
DesignTech disclaims any liability or responsibility arising out of any inaccuracies of this information or use of this information for installations or otherwise. Please verify all wiring for accuracy prior to making any connections.
Remote Starter Wiring Colors and Notes |
Function | | Vehicle Color | Location |
Start: | | YELLOW | IGNITION SWITCH HARNESS * |
Ignition #1: | | DK. BLUE/WHITE | IGNITION SWITCH HARNESS |
Ignition #2: | | DK. GREEN/ RED | IGNITION SWITCH HARNESS (TRANS.) |
Ignition #3: | | N/A | |
Accessory: | | BLACK/ ORANGE | IGNITION SWITCH HARNESS (HEATER/AC) |
Brake Light: | | WHITE/ TAN | AT SWITCH ABOVE BRAKE PEDAL |
Tach Signal: | | TAN/PINK, TAN/LT. BLUE | TAN/RED, OR TAN/ORANGE AT PCM * |
Parking Lights: | | BLACK / YELLOW | # PIN CONN. IN DRIVER'S KICK PANEL |
Headlights: | | YELLOW (-) | AT HEADLIGHT SWITCH ** |
Diesel Glow Plug: | | | |
Clutch Bypass Wire: | | | |
Notes: | | |
Alarm and Keyless Entry Wiring Colors and Notes |
Constant +12 Volts: | | RED & PINK/BLACK | IGNITION SWITCH HARNESS |
OEM Alarm Disarm: | | LT. GREEN/ ORANGE (+) | DRIVER'S KICK PANEL |
Dome Lights/Superv: | | YELLOW (-) | AT BODY CONTROL MODULE **** |
OEM Horn: | | BLACK/ RED (-) | AT FUSE BLOCK IN DIRVER'S KICK PANEL |
Power Lock: | | WHITE/ LT. GREEN | # PIN CONN. IN DRIVER'S KICK PANEL*** |
Power Unlock: | | SINGLE WIRE SYSTEM | # PIN CONN. IN DRIVER'S KICK PANEL*** |
Trunk Release: | | BLACK/ WHITE (+) | AT TRUNK RELEASE SWITCH |
Alarm Input Wire: | | YELLOW (-) | AT BODY CONTROL MODULE **** |
Notes: | | *** Single Wire Door Lock System; See Note # 217 - Cirrus/Sebring/Stratus Single Wire Door Lock Diagram. **** Body Control Module Is Located A Junction Block Behind Driver's Dash. |
DesignTech International, Inc. | Tel: (703) 866-2000 Fax: (703) 866-2001 | ©2002 All Rights Reserved |
7955 Cameron Brown Court Springfield, Virginia 22153 USA | 1-800-DESIGNTECH (1-800-337-4468) | DesignTech International, Inc. www.designtech-intl.com |
DesignTech disclaims any liability or responsibility arising out of any inaccuracies of this information or use of this information for installations or otherwise. Please verify all wiring for accuracy prior to making any connections. |
Tuesday, May 12, 2026
• Copyright © 1999-2026 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
