matching amps w/ subs
kfr01
Gold - Posts: 2,121
Posted: December 10, 2004 at 11:31 PM / IP Logged
You have a bandpass box.  These boxes create a frequency region "bandpass" where the SPL output is very high.  However, above or below this region the output drops substantially and when the subwoofer tries to create ultra low frequencies, those below the lower tuning frequency of the box, it will distort, bottom out, sound like ass, whatever you want to call it.  A 30hz high pass filter will start substantially taking out the frequencies below 30hz.  Since your subwoofer won't try to reproduce these low frequencies it has a hard time with, your bass will sound better playing what your box was meant to play.
Well, the MTX amp probably actually puts out what it says it does.  MTX is made by the same company (Mitek) as Coustic.  Coustic is the "value" brand compared to MTX.  Within that company the brand hierarchy goes Coustic < MTX < Xtant.  Coustic is better than Boss or Riot, but either way the MTX is going to be more honestly rated, tough, clean, and long lasting.  It is simply a better amp than those others.  Trust me, it is not worth going with a cheaper amp that "says" it does 600w or 850w.
New Project: 2003 Pathfinder
Xplorer
Copper - Posts: 69
Posted: December 11, 2004 at 11:59 PM / IP Logged
Any thoughts about a Hifonics Brutus BX1000D?
Peace
kfr01
Gold - Posts: 2,121
Posted: December 12, 2004 at 12:08 AM / IP Logged
Way more power than you need for that sub/enclosure combination.
Xplorer
Copper - Posts: 69
Posted: December 13, 2004 at 2:49 AM / IP Logged
if i could get it cheap should i do it or is it too much?
Peace
kfr01
Gold - Posts: 2,121
Posted: December 13, 2004 at 10:49 AM / IP Logged
I'd look for a better amp for those subs, but sure, just don't be an idiot with the gain or the volume.
Xplorer
Copper - Posts: 69
Posted: December 13, 2004 at 4:12 PM / IP Logged
when you say a "better" amp for those subs do you mean to say that the Brutus isnt any good or do you mean to say find an amp that is"better" suited (in power etc.) for those subs?
Peace
