1995 nissan 240 with factory amp
dominicb
Member - Posts: 12
Posted: December 12, 2004 at 2:15 AM / IP Logged
I am trying to hook up an aftermarket headunit and no sound comes out because of the factory amp.  What do I have to do to bypass it?  Is there a bypass amp kit that I can purchase?  If not, how do I go about bypassing the factory amp?  Any help would be greatly appreciated.
daze
Copper - Posts: 112
Posted: December 12, 2004 at 5:55 PM / IP Logged
Is it the bose sound system ? Have you taken out any of the speakers yet ? Did you have sound before you changed the radio ? Did you use a wire harness for the install ?
dominicb
Member - Posts: 12
Posted: December 12, 2004 at 7:15 PM / IP Logged
I have mb quart speakers up front.  The back speakers no longer exist.  I did have sound before I took out the crappy aftermarket headunit.
dominicb
Member - Posts: 12
I have mb quart speakers up front.  The back speakers no longer exist.  I did have sound before I took out the crappy aftermarket headunit.  And yes I am using a wiring harness for the install.
daze
Copper - Posts: 112
Posted: December 13, 2004 at 12:51 AM / IP Logged
did you hook up the blue/white wire ?
dominicb
Member - Posts: 12
Posted: December 13, 2004 at 1:06 AM / IP Logged
i figured it out.  everything works fine now.
Sunday, May 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
