2003 mazda tribute
Welcome Guest :)
thagreatone76
Member -
Posted: December 14, 2004 at 2:33 PM / IP Logged
Does anybody know where i can get, or does anyone have a wiring diagram for a 2003 mazda tribute.Please help.Thanks.
cerickso
Member -
Posted: December 14, 2004 at 2:48 PM / IP Logged
This should be what you are looking for.
Remote Starter Wiring Colors and Notes |
Function | | Vehicle Color | Location |
Start: | | Tan/Lt.Blue (+) | Ignition switch harness |
Ignition #1: | | Lt.GREEN/ Purple (+) | Ignition switch harness* |
Ignition #2: | | N/A | Ignition switch harness |
Ignition #3: | | N/A | Ignition switch harness |
Accessory: | | BLACK/ Lt.Green (+) | Ignition switch harness |
Brake Light: | | Lt.Green (+) | Brake pedal switch |
Tach Signal: | | See note | See note** |
Parking Lights: | | Brown (+) | Steering column or plug at the GEM module*** |
Headlights: | | N/A | |
Diesel Glow Plug: | | N/A | |
Clutch Bypass Wire: | | N/A | |
Notes: | | *This vehicle is equipped with a Transponder Anti-Theft Security System. **On the ZETEC motor use GREEN/ Purple or Lt.GREEN / WHITE at the coil pack. The Duratec motor has a coil for each cylinder, go to any one and use the wire that is NOT WHITE/ Purple. ***The Generic Electronic Module (GEM)is behind the center console on the floor. Pull off the black panel to the right of the gas pedal, there will be carpet covering it. The plugs face the drivers side of the car. |
Alarm and Keyless Entry Wiring Colors and Notes |
Constant +12 Volts: | | RED / Lt.Blue (+) | Ignition switch harness |
OEM Alarm Disarm: | | Blue/Lt.Green (-) | Drivers kick panel or plug at the GEM module*** |
Dome Lights/Superv: | | N/A | |
OEM Horn: | | Yellow/Lt.Green (-) | Steering column harness |
Power Lock: | | Pink/White (-) | Drivers kick panel or plug at the GEM module*** |
Power Unlock: | | Same wire as power lock | Drivers kick panel or plug at the GEM module*** |
Trunk Release: | | N/A | |
Alarm Input Wire: | | N/A | |
Notes: | | ***The Generic Electronic Module (GEM)is behind the center console on the floor. Pull off the black panel to the right of the gas pedal, there will be carpet covering it. The plugs face the drivers side of the car. Information indicates that a negative through a 1K resistor to the Pink/White will lock the doors. A direct ground will unlock. |
thagreatone76
Member -
Posted: December 14, 2004 at 3:06 PM / IP Logged
Tuesday, May 14, 2024
• Copyright © 1999-2024 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
