When the HU is the problem
bigboi11
Copper - Posts: 83
Posted: December 17, 2004 at 8:10 PM / IP Logged
I have been doing post after post trying to get my system right then someone told me that maybe its the radio and not the ground.  So I took my mp3 player and hooked it straight up to my amp started the car and the sound was crystal clear no ground loop or anything.  So then I got a fresh pair of rca's hooked them up from the radio to the amp and the disgusting fuzzing sound of a ground loop.  So now it has to be the radio .  My question to everyone is, is this just a pioneer thing, is it a defect or broken, or is this something that can be corrected?
auex
Platinum - Posts: 5,041
Posted: December 17, 2004 at 8:18 PM / IP Logged
Go to the rca's in the front and hook your mp3 player up there and see what happens. If you are running new rca's then go ahead and run a ground from the amplifiers ground to the radio's ground wire and see if that helps.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
bigboi11
Copper - Posts: 83
Posted: December 17, 2004 at 8:47 PM / IP Logged
I'm not running new rca's i just hooked up some new ones through the car.  to see if the old rca's were the problem.  arent the rca's in the front outputs.  What will I be looking for? if i run a ground from dist block to the radio it will be about 10 ft long maybe a little more.
