Need help with 2001 Frontier
jiggy2damax
Posted: December 20, 2004 at 4:39 PM / IP Logged
I got this wiring diagram:Battery GREEN (+) IGNITION SWITCH HARNESS
Ignition 1 BLACK/ WHITE (+) IGNITION SWITCH HARNESS
Ignition 2 RED / YELLOW (+) IGNITION SWITCH HARNESS
Ignition 3 (+)
Accessory 1 WHITE/ BLUE (+) IGNITION SWITCH HARNESS
Accessory 2 (+)
Starter 1 BLACK / YELLOW (+) IGNITION SWITCH HARNESS
Starter 2 GREEN/ YELLOW (+) IGNITION SWITCH HARNESS
Anti-Theft Type RF ACTIVATED SYS.
Anti-Theft Descript TRANSPONDER
Key Sense WHITE/ GREEN (+) IGNITION SWITCH HARNESS
Neutral Safety YELLOW (-) RELAY BOX PASS INNER FENDER
Tachometer PINK/BLUE (-) ELECTRONIC CONTROL MODULE (ECM)
Speed Sense GREEN/ BLACK (AC) ABOVE BRAKE PEDAL
Parking Lights BLUE/RED (+) BEHIND SWITCH AT WHT. CONN.
Brake Lights BROWN / RED (+) BRAKE SWITCH
Reverse Lights YELLOW/RED (+) DRIVERS KICK
Horn LIGHT GREEN/ RED (-) AT STEERING COLUMN
Doorlocks/Windows
Power Unlock BROWN (-) LF.KICK PANEL AT FACTORY SECURITY MODULE
PowerLock GREEN/ RED (-) LF.KICK PANEL AT FACTORY SECURITY MODULE
Driver Mtr Unlock GREEN / WHITE (+) FACTORY SECURITY MOD. LF.KICK PANEL
Driver Mtr Lock BLUE (+) FACTORY SECURITY MOD. LF.KICK PANEL
Pas Mtr Unlock PPL FACTORY SECURITY MOD. LF.KICK PANEL
LF Window Up LF-BLUE (+)
RF Window Up RF-BLUE / YELLOWDRIVER DOOR
SWITCH
LR Window Up LF-BLUE/RED (+)
RR Window Up RF-BLUE/WHITEDRIVER DOOR
SWITCH
Convenience
Headlights-Lo RED LF. RED / BLK RT. WHT 8 PIN CONN
Wipers-Lo WHITE/ RED (-) AT SWITCH
Modules
Module 1 RIGHT OF GAS PEDAL
Audio/Mobile Video
Battery PINK (+) RADIO HARNESS
Accesory BLUE (+) RADIO HARNESS
Ground GRAY (-) RADIO HARNESS
Illumination RED / BLUE (+) RADIO HARNESS
Dimmer RED / YELLOW (+) RADIO HARNESS
LF Speaker (+) PINK
LF Speaker (-) BLUE
RF Speaker (+) WHITE
RF Speaker (-) BLACK
The question I now have is how to wire up the scond starter, I was told I need one realy for a second starer kill and one for crank during remote start, Can I wire them up like this?  Btw: its a Viper 790xv.
2nd starters kill relay:
86- 12v
85- orange ground when armed output, same one that's hooked to starter kill 1
87a- key side of 2nd starter wire
30- starter side of 2nd starter wire
87- not used
2nd starter crank relay
86- 12v
85- purple ribbon wire, splice in up by the relay pack this is the - 200ma starter relay turn on
87- 12v
30- output to the 2nd starter wire, use a heavier gauge wire like all the others I think there 12g
87a- not used
jiggy2damax
Posted: December 20, 2004 at 10:05 PM / IP Logged
no1 knows?  com on guys
auex
Platinum - Posts: 5,041
Posted: December 20, 2004 at 10:14 PM / IP Logged
First, you don't need to use a starter kill on starter#2. Second you have the relay correcn for Starter Crank relay. Also you probably would have had an answer to your question earlier if you didn't copy your vehicle's wiring diagram to the post, too much reading without knowing the question.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
jiggy2damax
Posted: December 21, 2004 at 9:29 PM / IP Logged
K thanx. I thought it would be helpful.  I appreciate your help.
