Question on wiring
Carbonb
Copper - Posts: 113
Posted: December 22, 2004 at 1:44 AM / IP Logged
So I'll be running 2 12" JL W0's seperately. I am going to have them in seperate enclosures since I am going to be making glass enclosures on the opposite sides of my trunk.
Now I have an Alpine MRD-M301, I think the subs as are right now are wired at 4 ohm load, and the amp pushes at 150 x 1 at 4 ohms.
Now I want to wire them to the amp at 2 ohm load, since it pushes 350W x 1 @ 2 ohm load. I was wondering how I would go about doing this?
Since I am going to have 2 sets of speaker wires running to the amp and it's a mono channel. I don't know how to wire up the subs at 2 ohm and I don't know how to wire them to the amp.
Some help appreciated ;)
Carbonb
Copper - Posts: 113
Posted: December 22, 2004 at 1:51 AM / IP Logged
Also the subs are rated at 4 ohm and I looked at the requirements for air.
It says 1.0 to 1.75 cubic feet of air per sub? That's a big range?
spootydlux4
Copper - Posts: 149
Posted: December 22, 2004 at 1:52 AM / IP Logged
are they dual 4 ohm or dual 2 ohm?
blah blah blah blah
Carbonb
Copper - Posts: 113
Posted: December 22, 2004 at 1:54 AM / IP Logged
Single voice coil at 4ohm or 8 ohm.
spootydlux4
Copper - Posts: 149
Posted: December 22, 2004 at 2:00 AM / IP Logged
well if i am not mistaken, u can  wire them in parallel and they will produce a 2 ohm load
blah blah blah blah
spootydlux4
Copper - Posts: 149
Posted: December 22, 2004 at 2:01 AM / IP Logged
2 subs / Single Voice Coil - 4 ohms
Option #1
Question on wiring -- posted image.
blah blah blah blah
Carbonb
Copper - Posts: 113
If they are in seperate enclosures how could I go about wiring the subs parallel?
Also, how do they hook up to the amp?
spootydlux4
Copper - Posts: 149
Posted: December 22, 2004 at 2:02 AM / IP Logged
did that diagram show up?
blah blah blah blah
Carbonb
Copper - Posts: 113
Posted: December 22, 2004 at 2:08 AM / IP Logged
So I basically just run the posotive from both subs and negative from both subs together and then connect them normal?
I think this was another reason my subs weren't hitting. They were wired at 4ohm and were only getting about 75 Watts each.
spootydlux4
Copper - Posts: 149
Posted: December 22, 2004 at 2:14 AM / IP Logged
yep thats about it! tell me how they sound and get some pics of that trunk during the construction and when its done
blah blah blah blah
Thursday, October 30, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
